Not working
If this message is seen whenwhen you torn it on, either no Operating System is installed or the hard disk drive crashed. Either you'll have to install the OS or get and install another hard drovdrive.e
The system cannot detect the hard disk drive. Before you start up, re insert the hard disk. Remove the memory card and clean it with soft cloth or tissue paper. After doing these..Start up your computer and see the results. If nothing happens, restart your laptop, hit F12 key & set the hard disk drive to first boot device then press the Enter key. wait till the OS comes up.
SOURCE: My acer aspire 5738 won't start up it says
sounds like your unit did not detect the hard drive/hard disk.. try to enter on BIOS setup and check your hard drive or else you have a corrupted system.
OK, best case scenario is your hard drive is corrupt, worst case, hard drive is dead.
What to do - you could download the hirens boot cd and see if you can rejuvenate the hard drive firstly by going into mini windows and check if you can see the C: drive in windows explorer, if you can thern running chkdsk c: /f might sort it for you.
There are other utilities in the hirens disc that could help but that's where I'd start.
If you're not confident doing this then you might need to take it to your local pc engineer.
Instructions for System
For Multimedia Computer Systems, eg. Acer Aspire, Acer Veriton or Acer Altos, the serial no. can be found on the bottom right side of the system.
The serial number is : 7 alphanumerics characters or 22 alphanumerics characters.
Instructions for Notebook
For Notebooks, the serial number is found in the under-side of the notebook.
Instructions for Monitor (CRT/LCD)
For Monitors, the serial number can be found on the back.
The serial number is 22 alphanumerics characters.
