Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator Logo
A
Anonymous Posted on Aug 19, 2014
What is F2 - Fisher and Paykel Active Smart E522B Bottom Freezer Refrigerator
Sharp AR-M316 photocopier. f2-02 error on it. How can I clear f2-02 error on this Sharp photocopier please?
Sharp ARM316 - Error Code: F2-02
PrintCopy .info https://printcopy.info > model=ARM316 > code=F2-02
Code: F2-02; Description: Toner supply failure. The value judged from the actual toner supply hysteresis differs greatly from the toner sensor value.
Missing: photocopier. ā€Ž' Must include: photocopier.
1helpful
How do I get it to go into bios when pressing f2 doesn't work?
Per the internet site, it depends upon the model of laptop. Here are some examples:
Laptops - Access Bios Settings Key
Issue
The most common Access Bios key is the "DEL" button or "F2". This depends on the laptop model, however, and can be confusing if you do not know which key to press.
Solution
Here is a list of laptop models and brands with the keyboard commands / key for accessing the BIOS Setup:
Acer: F1, F2, CTRL+ALT+ESC
ARI: CTRL+ALT+ESC, CTRL+ALT+DEL
AST: CTRL+ALT+ESC, CTRL+ALT+DEL
Compaq 8700: F10
CompUSA: DEL
Cybermax: ESC
Dell Laptops:
Dell 400: F3, F1
Dell 4400: F12
Dell Dimension: F2 or DEL
Dell Inspiron: F2
Dell Latitude: Fn+F1 (while booted)
Dell Latitude: F2 (on boot)
Dell Optiplex: DEL
Dell Optiplex: F2
Dell Precision: F2
eMachine: F2
Gateway 2000 1440: F1
Gateway 2000 Solo: F2
HP (Hewlett-Packard): F1, F2 (Laptop, ESC)
IBM: F1
E-pro Laptop: F2
IBM PS/2: CTRL+ALT+INS after CTRL+ALT+DEL
IBM Thinkpad (newer) Windows: Programs-Thinkpad CFG.
Micron: F1, F2, or DEL
Packard Bell: F1, F2, Del
Seanix: DEL
Sony VAIO: F2
Sony VAIO: F3
Tiger: DEL
Toshiba 335 CDS: ESC
Toshiba Protege: ESC
Toshiba Satellite 205 CDS: F1
Toshiba Tecra: ESC then F1 or F2
Toshiba Notebook [Newer models]:
  • Turn on the computer by holding down the power button while pressing the ESC key
    • The machine will beep, then display:
    • Check System, then press [F1] key.
  • Release the ESC key
  • Press the F1 key
Laptops Access Bios Settings Key
2helpful
No fonctions
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
3answers
My Sharp Copier Model AR-M160 showing f2 error even I replace the new tonner.
Below are the F2 errors and causes for Sharp AR-M160
"F2-31" Image density sensor fault
"F2-32" Drum mark sensor fault
"F2-33" Grid voltage correction problem
"F2-35" Grid voltage correction problem
"F2-37" Drum mark sensor fault
Cause : CRUM chip defect OR Improper developing unit
Check and remedy : As you have already replaced the tonner, we can suggest Replace the CRUM chip,Replace the developing unit
Regards,
Shrey
9helpful
4answers
F2 error
Well F2 error codeis on a variety of Sharp copiers, the F2 error code would normally be accompanied by a sub code that indicates the fault, You may please check out the following -
You may post further comments for more help or information......
Good Luck!!
Thanks for using FixYa!!
The headlights won't come on
simple...check these fuses at the "Central juntion box"--F2-40, F2-06, F2-35, if ok then....F2-25 for LT lamp, F2-23 for RT lamp...if all good, check loom and connectors...knowing that the BULBS are good first....GL
1helpful
Fn+f2
fn+f2 means your pressing two keys at once
the function key (fn - usually a different color - maybe blue - than the letter keys) and the f2 key
hold down the fn first then the f2 - look for the fn on the lower right or left next to Ctrl keys
3helpful
F2 error
"F2-31" Image density sensor fault "F2-32" Drum mark sensor fault "F2-33" Grid voltage correction problem "F2-35" Grid voltage correction problem "F2-37" Drum mark sensor fault
Top Fisher and Paykel Refrigerators Experts
Grand Canyon Tech
Grand Canyon Tech
NOEL
NOEL
john h
Are you a Fisher and Paykel Refrigerator Expert? Answer questions, earn points and help others
