Magic Bullet Nutribullet Blender Logo
A
Anonymous Posted on Aug 17, 2014
HOT TO REPLACE THE RUBBER GASKET IN NUTRI BULLET
I CAN'T GET THE RUBBER GASKET BACK IN TO ITS SLOT...it seems to be too small. Is there a simple technique?
2answers
I need a replacement seal for a GNC On- The-Go Blender Model HL 2574
I found a replacement gasket that work for the GNC on the go Shaker HL-2574 if anyone need some just send me a msg yaz109 hotmail dot com
Jan 18, 2017 • Blenders
How do i repair my nutibullet .I have power but the blades on both extractors are not working . It gives out a loud vibrating buzzing sound when pulsing .last blast i did was watermelon and it worked...
Do not try repair it manually,as its a concern of electronic gadget,& its hazardous.Get it done from a service agent or instead prefer ton buy a new one.I would suggest Magic bullet blender nbr1201.The Magic Bullet consumes less power than Magic Nutri Bullet when you compare Nutribullet Vs Magic Bullet, but it is more when it comes to the price factor. Though it is not that powerful, you can get Magic Bullet at much cheaper price than Magic Nutri Bullet.Go to the link to know.
Nutribullet And Magic Bullet Difference
1helpful
2answers
Get the cup off the base, was making hummus, and now it still works, but wont let me remove the cup
put the cup area under some hot water near boiling and then undo the top with a cloth should come undone then, make sure its hot water.
Can I get a new gasket for a GNC on the go blender
Yes, you can order the replacement rubber gasket seal ring from nutri Bullet 600w or 900w which is the same size on ebay for $1.00.
Used the Nutri Bullet to make 5-6 smoothies. I could feel the base getting warm, not unlike in the past. I prepared to make another smoothie and nothing.... no energy, no noise nothing. Acted like no...
If the blades do not turn and you notice hot base hot or a burning smell, unplug the power base and let it cool for an hour. The powerbase will reset once the unit is unplugged.
They recommend not running for more that 1 minute bursts.
strawberry/banana num num !!!
3helpful
Blade stuck in nutribullet
I took it apart by removing the rubber spindle and three small screws. Then soak it in vinegar and rinse to remove food gunk. Lastly, re-lube with cooking oil (I used olive oil) by pouring onto back shaft and spinning the blades to suck in the oil. Reassemble. I still have to replace mine as the spindle is loose due to the bearings being worn out but at least it is useable again until then.
3helpful
5answers
Oster 6700 Gasket O-ring leaks
Gasket is not the problem.
Square shaft that is pressed into the turning gear is not tight and allows leaking through the connection.
Only repair is to replace the assembly with the gear drive, blades, etc. and this will take care of the leak. The "O" ring gasket is fine and holds the liquids. However the leak is around the center of the shaft that goes through the bottom.
Regards,
Gary
1helpful
Rubber Gasket
I would reccomend getting one directly from the manufacturer - their number is: 1-877-689-2737
If they don't sell the gasket separately, there are small appliance and hardware stores in some locales that will find the right gasket if you bring the machine in - I would call ahead to make sure.
-Tha Mp3 Doctor (also loves Margaritas)
Top Magic Bullet Blenders Experts
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
john h
Are you a Magic Bullet Blender Expert? Answer questions, earn points and help others
