Home Comfort HCWP1201 1.7 cu. ft. Portable Washing Machine With 12 lb Logo
k
keesha Posted on Aug 17, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why wont my home comfort 1401 washer drain but not spin
Washer will go thru normal wash cycle,water will drain but machine will not spin to remove excess water from clothes
Dennis
Level 2:
Sergeant:
  • Expert 232 Answers
  • Posted on Aug 17, 2014
Dennis
Expert
Level 2:
Sergeant:
Answers
232
Questions
Helped
59707
Points
546
There are many things that can stop it from spinning....but the
first place to check is the belt. Is it loose or broken?
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
7helpful
2answers
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
3helpful
2answers
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
2answers
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
Does washer drain before the spin cycle starts?
Normally yes. There are around 12 to 20 gallons of water in the tub after the wash cycle, which will be anywhere from 63 to 110 pounds of weight in addition to the weight of the clothes. For the machine to start the spin cycle to remove this water would place a heavy load on the motor, gearcase, pullys, belts, gears, ect. With the water drained, the load is lighter, and much easier to start spinning the excess water out of the clothes. The normal cycles are: Fill, Agitate, Drain, Spin, Rinse Fill, Agitate for rinse, Drain, Spin Cycle and off. Imagine trying to spin a 5 gallon bucket of water over your head, full of water, and then empty. Which one do you think would be easier to do? And safer for you.
2answers
Washers fine but doesnt drain water and go to rinse cycle
Check the drain hose may be kinked. Washers have been known to eat socks, they go in to the the tub during the spin cycle and down in the pump. If you are so inclined to look dome pumps are clear and you can see the sock. There is a hose clamp to remove and you may be able to remove the sock. Reassemble and test. Remember as always to unplug the washer first before doing any work. This exploded view has a washer and if you hover over the bottom right it will show what the pump looks like.
http://www.repairclinic.com/Washing-Machine-Top-Load-Maytag-Style-Appliance-Diagram Good luck
Water still in bottom of tub after drain/spin cycle
I removed the drain hose from the bottom left rear corner of the washer & cleaned a large amount of gooey sludge from the bottom of the drain inside the washing machine.
192helpful
18answers
Washing machine will not drain
I have a maytag washer that when it fills with water it wont drain out..the spin cycle just makes a noise and it wont do anything..any ideas what i can do to fix it thanks
Top Home Comfort Washing Machines Experts
john h
Are you a Home Comfort Washing Machine Expert? Answer questions, earn points and help others
