Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
A
Anonymous Posted on Aug 16, 2014
Where is the condensate drain located? - Maytag MFD2560HES Bottom Freezer French Door Refrigerator
Ty Roshdy
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Maytag Expert 650 Answers
  • Posted on Aug 17, 2014
Ty Roshdy
Maytag Expert
Level 2:
Prodigy:
Answers
650
Questions
Helped
137220
Points
915
It will be in the freezer behind the rear panel. You will most likely have to remove the rear panel in the freezer and pour hot water in the drain trough until the drain clears up and the water drains down the drain tube.
Santa fe 2014 ac condenser drain hose location
No such thing as a condenser drain hose. The condenser sits in front of the radiator.
Where are the condensing water drains?on a Coleman RV rooftop air conditioner
The condenser drains for a roof unit drain on top of the rv. There are on hoses which divert the condensation to a location other than the roof. Are you trying to keep it from dripping down at the door?
2answers
Where is the a/c condensation drain on a 2001 buik regal
a clogged ac drain will prevent the system from performing properly.
With a clogged drain \,ice tends to build causing the system to have ineffective cooling.The drain hose is located on the firewall,passenger side of vehicle
Condenser pan overflowing
Do u mean the evaperator drain pan.Were is it located in attic or in house closet.Because the condenser fan motor and coils are located outside.BUT ANY WAY DRAIN LINE MIGHT BE CLOGGED OR IN PAN-BLOW COMPRESS AIR INTO DRAIN LINE.CK END OF PIPES FOR CLOGG.
Where is the drain pan located?
Sometimes there is no condensate.
Sometimes the drain line is clogged.
Copy following links for GE Heat Pump water heater.
http://waterheatertimer.org/Review-GE-Heat-Pump-water-heater.html
Expanded drawing of 2012 GE heat pump condensation drain reservoir
http://waterheatertimer.org/images/GE-condensate-drain-560.jpg
Clean the drain line by swinging over head.
http://waterheatertimer.org/images/Black-Bud-tubing-350.jpg
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
Condensation water from air conditioner soaking front and rear passenger carpets. Where is drain located?
98 grand cherokee limited 5.2L same problem found leak not from heater box but from drain mount on firewall under the glove box not behind it. drain line should be located behind right front tire in the frame. Turn your wheels hard left look inside fender well right side towards back side. hole in frame where drain line should come out.
2helpful
Where is the drain pan on a carrier weathermaker 8000?
Hello, the drain line will be located under the unit near the condenser coil. Sometimes it can get blocked and the condensate will settle toward the front of the unit and leak from the unit. Also, make sure the unit is tilted back in the window about a 1/4 inch aswell.
My air condition window unit is spitting water how do I get to the drain line to clean it?
Hello, the drain line is usually located under the unit on the condenser side. If the unit does not have a drain then the unit is not tilted back enough to allow the condensate to be picked up by the condenser fan and splashed on the condenser to evaporate.
1helpful
I have a 2006 saturn ion 2. Just recently, my ac is draining into the passenger floor board. How do i fix this ?
Bulletin No.: 03-01-39-011B
Date: November 22, 2005
TECHNICAL
Subject:
Water Leaks Into Passenger Compartment Through HVAC Module Condensate Drain Tube When Parked on Incline/Uphill Position (Install Auxiliary Drain Tube Extension)
Models:
2003-2006 Saturn ION Sedans and Coupes
Supercede:
This bulletin is being revised to include the 2005 and 2006 model years. Please discard Corporate Bulletin Number 03-01-39-011A (Section 01 - HVAC).
Condition
When vehicle is parked on an incline with the front end up during a rainstorm or when driving uphill during a rainstorm, water may leak into the passenger compartment through the condensate drain tube opening of the HVAC module.
Cause
Water may drain out of the cowl drain, then drain down the front of the dash panel in the engine compartment and seep into the HVAC module condensate drain tube opening. The water then collects in the heater core cover and upon acceleration may leak into the passenger compartment through the heater core cover seams.
Correction 1. Open the hood and locate the HVAC module condensate drain tube in the engine compartment on the right side of the dash panel.
Important: During installation of the auxiliary drain tube, do not make contact with the HVAC module foam gasket located at the base of the HVAC module condensate drain tube. If the auxiliary drain tube is pushed on too far and makes contact with the foam gasket, water may leak into the passenger compartment.
2. Slide the auxiliary drain tube onto the HVAC module condensate drain tube and make sure that the auxiliary drain tube is angled downwards after installation.cansmo_121.gifcansmo_122.gif
4answers
Water/condensation is backing up in the bottom of the unit and overflowing into the house.
The drain in the condensate drip pan is clogged. Locate it and clean it out.
Charlie
Top Maytag Refrigerators Experts
vince
Johnny 1000
Jesse Walters
Jesse Walters
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
