Starts & runs but stalls when I release the brake, have checked all safety switch circuits, seem to be fine. Replaced seat delay module. Same problem, I am at a loss
SOURCE: toro snow master 20 will run and perform well but
Hi
Most common problem is gummed up carb. Have the carb cleaned and i that should take care of your problem.
Sam
Testimonial: "Thank you so much as soon as i can i will get it cleaned up thanks for the info i do appreciate it very much."
SOURCE: toro z master 252, starts ,runs 8 to 10 min. shuts...
One suggestion wouild be to check the spark right after failure. You can buy in-line spark indicators that give you a visual light if you are getting spark. This way you could see if you are losing spark when the engine warms up. If your spark is good, you would want to check the compression after the engine is warmed up and quits. You should have at least 100# minimum.
SOURCE: toro timecutter z4220. i just
release the park brake and try that,brake has to be engaged to start
SOURCE: engine runs till warm and then stalls out. Is
Try removing the gas cap. If that solves the stalling, clean the vent holes on the cap.
Gary
SOURCE: I have a Toro 20462 power mower -- about 15 years
Remove and clean the brass bolt that holds the float bowl on the carburetor. Clean out the bowl too. Use no metal objects to clean this bolt. It has 3 small holes...bottom...and on the sides near the top. Use carb/choke aerosol spray cleaner on it. IT can clog (esp. without an inline fuel filter on mower). Clean the bolt good, reinstall (not forgettting felt gasket between IT and the bowl) and your runnability problem and fuel flow problem should be solved as the bolt is also the main jet of the carburetor.
