WILL FILL BUT WANTER RUNS RIGHT OUT THE drain
SOURCE: Whirlpool Front-Load Washer AWZ 410, washer will not spin or agitate
control bord faulty just change this,-------wakilnme@yahoo
SOURCE: washer will not fill up with water...runs right back out of drain tube
Make sure the drain pipe is at least 34 inches above to bottom of the washer and that it is not sealed at that point. This will prevent siphoning.
SOURCE: My washer did fill, but
Hi tragz,
If it can't drain, it won't spin. There may be something preventing the pump from draining in the Pump filter. You will need to clean it.
Please follow my below Tip on how to do it:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER
Kind Regards d")
* If this solution helped you, please rate it
SOURCE: Kenmore washer 90 series continue
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
SOURCE: My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
