G
Greg Manvelian Posted on Aug 15, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do you remove the printer head to clean it?
How do you remove the printer head in the Cannon MX892 in order to clean it?
Rod Eslinger
Level 2:
Legend:
An expert who has written 200 answers of more than 400 characters.
  • Cannon Expert 307 Answers
  • Posted on Aug 15, 2014
Rod Eslinger
Cannon Expert
Level 2:
Legend:
Answers
307
Questions
Helped
419991
Points
456
Regarding your recent inquiry about your MX892 poor print quality/lack of printing performance (or similar), it sounds like your PRINTHEAD is either clogged (from dried ink) or has reached END-OF-LIFE, to help determine which please perform the following steps (if you have already performed a step, please continue to the next step in the order shown):
Canon Cartridge Troubleshooting: http://inkjet411.com/?page_id=1537
1.Go into the printer\'s maintenance/tools menu and print a print quality test (i.e. heading cleaning, nozzle test or similar) to help identify which color (of number of colors) is impacted.
NOTE: To help determine which color has run out, use the following suggestions in sequence until you are able to identify the empty color:
1) Generate a Print Quality Test Page from your printer control panel; a faded color band indicates empty. 2) To distinguish between a black and photo black cartridge, print a text document and/or a photo. Faded black in a text document indicates the black cartridge is empty; faded black in a photo indicates the photo black cartridge is empty. 3) To distinguish between cyan, yellow, and magenta click here: http://inkjet411.com/?page_id=146 A faded or missing color band indicates empty.
2.At the printer\'s control panel under the \'Maintenance\' or \'Tools\' menu, activate a \'CLEANING\' or \'HEAD CLEANING\' to prime the ink system. Then Run the Inkjet411 \'Ink Recovery Test Print\' from our Test Prints page to verify all colors are firing properly (all printers also provide some form of a Self Test page): http://inkjet411.com/?page_id=146
3.Check your user\'s manual to see if there are any procedures on cleaning the service station/capping station assembly (this is where the carriage/cartridges \'park\' when not in use). A dirty service station can cause all kinds of improper color output problems (assuming the printhead is working correctly of course). NOTE: May not be applicable for your model depending on the printer design.
4.If this does not remedy the problem, then one or more of the ink ports may be dry within the PRINTHEAD assembly (the ink cartridges physically connect to this electronic assembly). We suggest you either remove the printhead and perform a hot water flush for 2 minutes (in a sink) or using an eye-dropper, or similar, drip 5-10 milliliters (i.e. 1-2 teaspoons) of distilled water into the respective color ink port to help saturate the foam. http://inkjet411.com/?page_id=2804
7.Reinstall ink cartridges and retest.
      Inkjet411 Suggested PRINTHEAD Cleaning Procedures:
      Canon Printhead Warm-Water Flush Procedure: http://inkjet411.com/?page_id=2804
      3rd party PRINTHEAD CLEANING solutions (for additional reference only):
      http://www.youtube.com/watch?v=FL8QaFVwsEs(Canon)
      http://www.youtube.com/watch?v=ZheZf-vdho8 (Canon Printhead removal / water flush)
      8.If the problem persists, then you may have a damaged PRINTHEAD (worst case scenario), unrelated to the refilled cartridges. The printhead is a separate electronic assembly (which the cartridges are installed into) and is responsible for firing the ink drops onto the paper. Over time and based on usage this assembly will eventually fail (typically lasts ~4,000 to 5000 printed pages on avg). Refer to video on how the PRINTHEAD functions: http://inkjet411.com/?page_id=2054
        PRINHEAD TECHNICAL NOTES:
        IIT (individual ink tank-based) printer models have an electronic PRINTHEAD within the base of the carriage assembly (responsible for pulling ink from the 4, 5 or 6 ink cartridges and then firing the ink droplets onto the paper) - these will eventually fail depending on print usage type and printer duty cycle (i.e. rated for approximately 10,000 printed pages over life, but the consumer average is typically closer ~4,000-5,000 thruput pages). The printhead is replaceable and can be ordered directly from the manufacturer or www.Amazon.com . For information on how the PRINTHEAD functions, please watch the following video: http://inkjet411.com/?page_id=2054
        Typically the printhead should not reach it\'s end-of-life until after a minimum of 8 or more complete sets of cartridge changes. While some printheads may last 10,000+ pages others may only last 2000 pages, actual results will vary. The printhead will eventually fail in time due to an internal micro-electronics failure, due to the following leading factors: general customer print usage and printer care, printer duty cycle (i.e. # pages printed per month), printing frequency (i.e. time between each print job), print mode (i.e. draft vs. normal) and content printed (i.e. photos vs plain pages) and color mode (black and white only vs. color/greyscale printing).
        Paper types used (i.e. plain paper, photo papers & matte/heavy bond papers) and paper edge curl (i.e. duration in printer and/or exposure to low relative humidity) can also quickly lead to premature printhead failures due to physical \'head strikes\' of the paper edges making repeated contact with the printhead nozzle plate surfaces.
        For any additional questions please contact us directly: [email protected]
        NOTE: If you need to purchase a new ink cartridge(s), we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA and have a high reliability rating.
        -Thank you
3 Related Answers
Anonymous
  • 555 Answers
  • Posted on Jun 05, 2008
SOURCE: cannon printer model s530d serial # fbbh42792 receiving
You need to reset the printer
Anonymous
  • Posted on Nov 11, 2009
SOURCE: cannon MP510 printer has Error, - The type of print head
I solved this on mine by removing and reinstalling the print head.
1. Remove and set aside the ink cartidges (don't make a mess)
2. lift the gray print head lock lever that is to the left of where the ink cartridges go.
3. Lift out the print head out without touching the ink ports inside, the contacts on the back, or the print nozzles on the bottom. The print head is the grey thing with circular ink ports that seat the ink cartridges. there are good pictures in the PDF of the Easy Setup Instructions available on the Canon Printer website. Look under the printer, then support, then downloads: http://gdlp01.c-wss.com/gds/0900002776/mp510_esi_us_v2.pdf .
4. Put the print head back in, lock the lever, reinstall the cartridges in the roper positions. And voila!
If this doesn't work you may actually need a new print head.
Anonymous
  • 4 Answers
  • Posted on Jul 31, 2010
SOURCE: Epson 1200 Photo Printer
There is no way to remove the printhead to clean. I would not suggest you doing it as you need to have it aligned properly after cleaning. I suggest that you go to the nearest Epson service center to have it done.
Canon MX892 printhead bad?
hi
find link for how to clean the printer head
https://www.youtube.com/watch?v=ZGElrMuU8m4
Canon mx892 shows error code B200: Printer error has occurred. Unplug the power cord and contact the service center
The fault in Canon Printer Error Code B200 indicates a defective print head. A print head is a component that directly collects the ink onto the paper from the cartridges, which means it's one of the most critical parts of the printer.
Canon Printer Error Code B200, which can signify a hugely damaging system error, is one of the most feared.
Want to Correct the B200 Canon Printer Error Code?
1. Unplug and leave your printer disconnected for a minimum of 30 minutes.
2. Open your printer's door and you can move the print head so you can reach it.
3. Take off old ink.
4. The complete Canon Printer Error Code B200 solution.
Check this Blog - Canon Printer Error B200
Cannon error codes
Printer is in use or an error has occurred. check status. Scanner driver will be closed.
code 2,140,2
if scanner is not in use there is a problem using it with the USB unplugged.
1helpful
2answers
Cannon mx860 fails to print in black ink. loaded new cartridge, still doesn't print in black. will print in color..
With the Canon MX860 you can removed the print head assembly quite easily and clean it with water. I have posted a youtube video for your reference.
Canon MX892 - when I scan, an error code 2156 comes up saying scanner is turned off or usb cable unplugged
Hi.
Try to check up first scanner power cable and network wireless router.
If it are running running good. your scanner have defective parts. like
IC chipset.
Second option : try to general cleaning your Canon PIXMA MX892 Network-Ready Wireless All-In-One Printer. using vacuum.
Hope can help you.
Cannon i 960 printer
Try first replacing the cartridge , possibly with an original one.
With new printer cartridge on do head clean a couple of times, to clean the print head.
If it still prints wrong color then the print head is faulty, one of the colors jets is clogged.
You can remove the printhead and leave it in cleaning solution or isopropyl alcohol overnight, probably you will need to replace the printhead.
Top Cannon Office Equipment & Supplies Experts
NOEL
NOEL
Grand Canyon Tech
Grand Canyon Tech
Are you a Cannon Office Equipment and Supply Expert? Answer questions, earn points and help others
