Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
A
Anonymous Posted on Aug 14, 2014
Valve settings need valve settings
snowmanii
Level 2:
Sergeant:
  • Craftsman Expert 479 Answers
  • Posted on Sep 04, 2014
snowmanii
Craftsman Expert
Level 2:
Sergeant:
Answers
479
Questions
Helped
139014
Points
943
Most valve clearances for b&s are about a sheet of papers thickness. If you would like exact measurement, get me the model number of the engine and I will attempt to find it for you.
1helpful
Overflow valve on tankless Rheem was leaking & replaced with valve that has sensor from home depot. It is still leaking. Is there a specific overflow valve that I need to use on my tankless system?
The valves are the same specs. Is it possible that a new valve leaks, yew. However if both valve leak then there are other problems. Does the valve only leak when hot water is called for? Then check temperature setting on heater. Does it lek all the time? The water pressure is to high ,
  • Maximum Temperature Setting (Deg. F): 210
  • Maximum Pressure Setting (psi): 150
Why the relief valve at the water heater is leaking and what to do about it
Does tankless water heater require pressure relief valve
I have a model 44P777, Type 0412 E1. I need the intake rocker setting and the exhaust rocker setting. I also need the spark plug setting. Thank you.
You can set your valves at .004 thousandths, and the spark plug is set at .030 thousandths. GOOD LUCK FRIEND.
Sep 16, 2014 • Garden
1helpful
How do I set the timing
Are you trying to set the ignition or valve timing ? The ignition timing is factory set and changes with engine rpm - you can set the air gap between the flywheel and the ignition unit which should be around 0.25mm (0.010") Excessive air gap will retard the ignition timing. Unless you\'ve had the engine apart, the valve timing won\'t need re-setting. The valve clearances will need setting from time time and the clearance between valve and rocker is 0.1mm and is adjusted with both valves closed and piston at the top of it\'s stroke - you should replace the gasket and copper washer at the same time.
I needed gap setting for a hnda over head cam gcv 160 5.5 h/p [valves setting ]
.006in on the Intake and .008in for theExhaust + or - .002in
Jul 02, 2012 • Motorcycles
6helpful
How do i set cam position and timing on an old yamaha xt 500
You didn't say WHY the cam / valve timing needs to be reset. For some reason I get the feeling someone told you that resetting was needed and so you are asking how. Obviously, you may have installed new pistons and that is why the resetting is needed. In either event, when the cam timing is set the valve timing is also set. Other than adjusting valve lash, setting the cam sets the valve timing. Below is a web site where you can do a free download of a factory service manual. The process is not hard but having a manual will be more help and faster help than I can give online.
http://www.carlsalter.com/motorcycle-manuals.asp
2answers
Need help with valve adjustment specs
Exhaust power valve adjustment for "stock setting" is: 1/2 turn out from closed.
31helpful
4answers
2001 yamaha warrior valve adjustment
hello
with the cylinder set at top dead center compression. using a feeler gauge between the tappets and the valves there should be .002-.003in clearance on the intake valves, and .006-.007in. clearance on the exhaust valves. thank you.
2answers
Spark plug change
Well i wouldent of thought you need to take off the valve cover AKA (rocker cover) to change spark plugs. spark plugs are usally set at a touque setting at 10 to 15 NMs (newton meters). if you do have to take off the valve cover the gasket can be re-used no O-rings needed.
Top Craftsman Garden Experts
john h
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
