Frigidaire Professional Series 24 in. Built-In Dishwasher Dishwasher Logo
A
Anonymous Posted on Aug 14, 2014
Grinding sound in FGHD2472PF frigidaire professional
I have a grinding sound in motor. Is there a chart online that I can find to troubleshoot cycles. Step thru the cycles instead of waiting
  • Official Brand Answer 2,267 Answers
  • Posted on Aug 19, 2014
Frigidaire
Level 0:
Answers
2267
Questions
0
Helped
1289821
Points
2557
Hello friend, thank you for your inquiry!
I understand that your Frigidaire dishwasher is making a grinding noise. Typically that noise could be a faulty motor/pump. I have included a link to your manaul. If that does not help I would recommend having a technician out to your home to properly diagnose and repair your appliance. Best of luck. -Matt
Frigidaire Manual Search Results
1 Related Answer
Anonymous
  • 6784 Answers
  • Posted on Jun 18, 2009
SOURCE: Frigidaire dishwasher model FDB857RJS1 not pumping
HI, under the sump housing, there is a major issue concerning the circulation motor. there is a wash impeller that is connected to the circulation motor, via drive shaft and stud. this assembly has been stripped, due to a possible jam that was caused by a foreign object. the impeller is basically, producing the grinding sound you are hearing, you will need to replace this damaged wash impeller asap. it will ruin the motor soon if it is not removed.
This wash impeller is responsible for the flow of water during the wash cycle. it is not completely off the shaft but, eventually , it will break off soon, causing major damage to the circulation motor.
Fisher and Paykel front loader grinding noise
There could be a few possible reasons for the grinding noise in your Fisher and Paykel front loader washing machine. Here are a few things to check:
  1. Check the drum paddles: If the drum paddles are worn or broken, they can create a grinding noise during the wash cycle. Check to see if any of the paddles are loose or damaged.
  2. Check the drum bearings: The drum bearings are responsible for supporting the drum and allowing it to spin smoothly. If they are worn or damaged, they can cause a grinding noise. To check the bearings, try spinning the drum by hand. If it makes a grinding noise or feels rough, the bearings may need to be replaced.
  3. Check the drive belt: If the drive belt is loose or worn, it can cause a grinding noise. Check the belt for any signs of wear or damage, and make sure it is properly tensioned.
  4. Check the motor: A faulty motor can sometimes cause a grinding noise. If you suspect the motor is the problem, it's best to call a professional for assistance.
If none of these solutions fix the problem, it's best to call a professional to diagnose and repair the issue.
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Frigidaire professional series micro wave is making a grinding noise
Good Morning friend, thanks for your post!
From the information you have provided your Frigidaire microwave is making a grinding noise. This could be a possible problem with your motor or magnetron. I would advise to remove the plate on the inside of your microwave and check to assure no dirt or debris is holding the movement of your bottom plate. You may want to perform a reset on your microwave and you can do that by disconnecting power from it for roughly ten minutes. If that does not work you may need to have one of the electrical components replaced on the inside of your microwave and I would recommend having a professional technician out to perform repairs. This will help to avoid any future issues or personal injuries. -Matt
Why is there a grinding sound from the washing machine, how to fix?
Without the model number it is hard to say. The motor wont make a sound like that. IT is most likely the transmission.
Front load washer will not spin
Good Afternoon Kevin,
I see that you are having trouble with your Frigidaire washer not spinning and making a grinding sound as if something were stripped. I also see that changing out the door lock and switch assembly, did not help the issue.
I would suggest contacting either the manufacturer or your local authorized technician for further assistance. They will be able to diagnose what is causing the grinding sound and better assist in resolving the grinding sound. Hope this helps.
-Best Regards-
WP
Grinding noise before spin cycle
Good Morning John,
I see that you are hearing a grinding noise before the spin cycle in your Frigidaire washer, model# GLET1031CS0. A certain amount of "grinding" or gear sounds are normal in a heavy-duty washer. If you notice that the grinding sound appears to be getting louder, I suggest contacting either the manufacturer or your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Dishwasher is making a loud noise
Sounds like there is something in the filter trap that is right before the mini disposal that is a fan blade, on top of the motor.
3helpful
Loud sounds
Many Frigidaire dishwashers come with the promise of being the "quietest dishwasher in its class," according to Frigidaire. However, a quiet dishwasher doesn't necessarily mean that the dishwasher is silent, as some noises are normal. It can take some troubleshooting at times to determine if a noise coming from the dishwasher is typical or if it indicates a larger problem Listen for the sound of water filling and draining throughout the wash cycle. These sounds are normal and do not indicate an issue.
  • 2 Pay attention to the drain motor, which operates at the beginning of each cycle. This noise should be fairly quiet and should not sound like a loud, grinding or banging sound.
  • 3 Note that the sound will change when the wash cycle moves between the lower and middle spray arms. This sound should be temporary and fairly quiet.
  • 4 Look for hard items in the dishwasher grinder or filter if a loud crunching, buzzing or grinding sound is heard. The dishwasher can typically grind up these items within one or two cycles, but the item may be lifted out and discarded to eliminate the sound.
  • 5 Remove the bottom rack and spray arms from the bottom of the dishwasher if there is a loud noise coming from the dishwasher that does not resolve itself. Look inside for the impeller, which is round and spins. Remove any debris that may be clogging up the impeller or pump.
  • 0helpful
    Frigidaire dishwasher model FDB857RJS1 not pumping water to the top arm. runs then makes a grinding sound like the motor skipping a gear then back to moving water but not enough pressure to get to the top...
    Top Frigidaire Dishwashers Experts
    Mike Cairns
    Mike Cairns
    ZJ Limited
    ZJ Limited
    Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
