Will not open and buzz sound and it states FL code
SOURCE: Maytag Neptune MAH5500BWW Dont Wont Open
There is a cord you can pull under the soap tray.
Read here:
http://www.applianceaid.com/neptune3.html#lock
SOURCE: Maytag Neptune front load door is stuck
Pull cord under soap tray.
Read here:
SOURCE: Maytag Neptune washer error FL
There is a manual door release tab in the dispenser area. You have to take the screws out and remove the dispenser to pull the tab and release the door. This is a pretty common issue, if you haven't yet you should contact your Maytag authorized dealer and ask about a more permanent solution. Hope you can get your clothes out.
Thanks
I’m happy to assist further over the phone at https://www.6ya.com/expert/ryan_7b238a1b08d97b98
SOURCE: the washer buzzes and shows
It appears that the door latch safety interlock was damaged or broken when the door was opened mid-cycle.
The codes "fl" Failure and "do" Door Open, seem to indicate that the latch and/or door switch need to be replaced. I tried to find a drawing and parts list for your washer, based on the model you selected, but could not locate one. If you can get the full model number, you can check for the replacement part at searspartsdirect.com or call them to get the part number.
If you look inside the door of the washer, you can see if the catch (on the moveable door) or the latch, on the washer cabinet) is the broken or damaged.
The repair is relatively straightforward and easy to do, with simple hand tools. Just make sure to disconnect the washer power cord before doing any work on it. Once you've done that, open the door and remove the screws and you should be able to remove either or both, the catch and the latch switch and reinstall the new ones, once you have them.
That should resolve the problem you're having.
Hope you find this Very Helpful and best regards!
