HDMI is a digital signal, so your TV and your PS3 are basically talking to each other over the connection at all times. That's why when you plug an HDMI connection into your PS3, it can detect the connection and try to switch right to it. Component cables don't work the same way, they only output information, so it's a one way street. Your PS3 is still outputting information, but it still thinks it needs to output to the HDMI port. The fix is pretty simple, and there are two options.
The Long Way
- Plug your PS3 into an HDMI TV.
- Change the Audio settings first, so your console outputs audio to a Component source.
- Now change the Video settings last, so the PS3 is outputting to a Component source as well.
- Your screen should go blank once you do this. Hit the X button once, wait a moment, then use the power button on the front of the PS3 and turn it off.
Now just plug the PS3 into the other old TV with the Component cables, and turn it on. You should have picture and sound now.
The Short Way
- Leave the PS3 plugged into the old TV, and turn it off with the front power button. Once the light has turned Red, hold the power button down for at least 5 seconds. Don't let go until you should hear the system beep twice.
Now you should be able to use your PS3 on the older TV without a problem.
The Short Way is a simple reset of your video card, it causes the PS3 to revert to outputting to it's out-of-box settings. If neither of these ways worked, check here at the
Sony website, and one of those solutions may better fit you, but it sounds like one of the two solutions above should solve it.
Please leave a comment or rating letting me know if this solved your problem, constructive feedback is always welcome. Good luck with your console and good luck with your games.
