This only sounds like a blockage in the condensate collection pan below each evaporator. Your model has a evaporator below each the freezer and the fresh food compartment. You will need to unplug the refrigerator ansd remove the panels covering these evaporators in order to see these condensate collection trays. Go to page 81 in the=>
Sub-Zero_Built-in_500_Series_Refrigerator_Service_Manual.pdf You are going to have to remove these panels to understand what to look for when it comes to condensate collector pans with the drain in the middle bottom of each. Ask questions if you want I am here to help, Thanks
Sea Breeze I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers. This is not always the same with every model as you may see frozen ice flowing down the rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more simple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the
drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you run into any problems along the way of repair please let me know, Thanks, Sea
Breeze
