Just received my player in mail, charged for 3 hrs, but it will not turn on, what can i do
From the Sansa site:
Sansa Fuze is not turning on or charging
1. Press-and-hold the POWER button for approximately 30 seconds to reset the player.
2. Connect the player to the PC. The players's display screen should turn on and start charging within an hour.
3. Allow the player to charge for 2 to 3 hours.
4. Update to the latest firmware to prevent this issue from occurring again.
Hold the on/off slider for 30-40 seconds and then release to reset the device. Then try turning it on. Also, sometimes if the battery is low/dead it will take longer than 3 hours to charge up. If it does not turn on after the reset you might try letting it charge for a day or so and try again. If it doesn't work after all of this, it should be returned to where ever you bought it for a replacement.
SOURCE: lOST INSTALLATION DISK FOR SANDISK SANSA FUZE
go to this website , they will have what you need to download, www.sandisk.com
SOURCE: Need User Manual for SanDisk Sansa Fuze MP3 Player
Try this site [manual in pdf-format]:
http://www.sandisk.com/sansa/assets/English/products/Fuze/fuze_userguide_en.pdf
SOURCE: my sansa fuze wont charge
Some USB ports cannot supply enough power to charge the Fuze. I had the same problem. I worked around it by getting a wall charger from RadioShack.
SOURCE: I need to reset sandisk sansa fuze 8gb
Press the Power and Play (>||) button together for 20 seconds to reset the unit!
