Code
E225-0001
Description
Light intensity of a lamp is less or equal to the criteria
Remedy
When the same error repeatedly occurs after several times of turning the power OFF/ON, execute the following remedies.
(1) Check the connection of Flat Cable between Main Controller Board (J5) and Contact Sensor.
(2) Replace the Flat Cable between Main Controller Board (J5) and Contact Sensor.
(3) Replace the Contact Sensor. (4) Replace the Main Controller Board.
SOURCE: canon pixima mp140 error code E4
following error codes i found
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber full
SOURCE: cannot copy or fax - Canon i-sensys L140
CHECK THE ADF
IT IS JAMMED OR NEEDS TO BE REPLACED!
CHEK AGAIN ..EVEN THE TINNEST PIECE OF PAPER CAN JAM IT.
SOURCE: Error Code for Fax Canon L220
You need to service machine and may be your fixing unit is problem
> If that replace Fixing Unit
SOURCE: WILL NOT PRINT. SCREEN
ok..first things first...how about doing a test page, without the computer attached?
http://tinyurl.com/6qcpgy
SOURCE: Canon Image CLASS MF6550 not printing
hi kim
you have a stuck shutter in front of laser unit very common problem
charlie
