Tractor does not start. Why does it not even turn over? Why did it suddenly stop while running without any warning? what should my next step be?
DOES IT TURN OVER BY HAND? IF IT WAS LOW OR RUN OUT OF OIL IT MAY HAVE SEIZED UP AND THE CRANKSHAFT AND CONNECTING ROD HAVE LOST THEIR BEARING SURFACE AND SEIZED. pERHAPS YOUR STARTER MOTOR IS FROZEN UP AND NEEDS REPAIR/REPLACEMENT. i DON'T HAVE MUCH TO GO ON WITH THE SHORT DESCRIPTION AND NOT MANY DETAILS.
SOURCE: runs but will not go
Hello brookspiercy:
From your Description it Sounds like a New Belt is Required and Possibly a New Clutch Idler Arm or Idler Pulley. The Grinding Sound like it May be the Bearings of the Clutch Idler Pulley.
>>For Better Assistance,
>>Send me the Model Numbers Off the Mower, Please. With these I can Locate the Proper Manual and Better Assist you. The Model Numbers are Usually Located Under the Seat on a Sticker or Tag on the Body.
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
SOURCE: Have a Toro LX 465 lawn tractor, won't start;
Could be your coil. Might be bad or it went out of gap. Gap is .10
SOURCE: my Lt 1050 Pto just stopped running and now it won't start
test the safety switch on the brake pedal and the pto switch
