SOURCE: Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
SOURCE: door handle of washing machine broken
if clothes are still in washer? and machine has finished cycles? then handle broke so unable to open ??? your best option is to unplug/ and if necessary disconnect water supply hoses then remove the top screws from rear panel which also secure the top panel as you will observe ? then pull backwards top panel and loft off ? you now have access/visual of the door catch inside front machine look?? at the catch and you will see how it locks ? you can lever the catch gently and door opens to fit a new door catch is easy diy and not expensive if you are confident usual problem these break ? is the time delay micro switch sticks with age /moisture try dw40 and work plunger b4 you refit door back after replacing handle/catch assy
SOURCE: lg washing machine wm-1460fhd door locked wont
We have a WM-1480FHD, with the door stuck shut. It appears the door release mechanism in the actual door has broken, so when you pull the lver part, the catch is not released. You need to get a very flat knife,insert between the door and the front of the machine, right in the middle behind the release handle and push the hook towards the right side of the machine.Once open, you can check the release mechanism in the actual door. Ours is broken, so need to sort out how to repair/replace it next!
SOURCE: Lg WM0532HW washing machine control panel say OE
"OE" means that your drain pump is blocked, or possibly broken, and that water isn't emptying so that the machine can spin. (I think Outlet Error is what it stands for). If you have a wet dry vac, you can use it to vacuum out the water from the drain hose behind the small door on the lower left side of the machine. If not, you can try using a large pan to catch the water, but to be honest, it will take forever and won't really get all the water out. Try to borrow a wet vac if you don't have one.
Next you will have to open the pump trap (the cap thing next to the small drain hose). With the wet vac on and in position, loosen the trap and pull it out slowly (there will still probably be a bit of water in there). Hopefully you will find a bunch of junk in the trap like lint, coins, a sock, whatever... however you may find there isn't anything in the trap. which means we have to go in deeper.
You may just want to get a pro in to do this, but it isn't really all that difficult for the adventurous type. You have to remove the top of the machine (three screws at the back release it so that the top panel can slide back a couple inches and lift off,) pull out the dispenser drawer completely, the control panel (you don't have to disconnect the wires, just pull it away from the frame of the machine so that it reveals the screws that hold on the front panel) Then you have to remove the front panel, which includes pulling off the spring clamp that holds the gasket to the front panel, and the wire which activates the door lock. There is also a screw behind the plastic piece where the drain hose is.
Once you can get to the pump, unscrew the motor on the left side of the pump and remove whatever is blocking the pump impeller from turning... even a tiny nail can do it.
SOURCE: lg washing machine wm1832cw door is locked with
This is most likely due to non-pump out of the water. It could be a plugged filter or a bad pump motor. First thing to do is to get a pan or bucket and open the big screw filter behind the access door at the lower left on front of the machine. All the water will come pouring out, so be ready. Machine will probably unlock on it's own then. (if it is still plugged in) If not, you can take the top off by removing the screws on the bottom of the plastic clips at the back of the washers top. Now, standing in front of the machine, use the palms of your hands to sharply push the top back about an inch, then lift the top off. With machine unplugged, you can reach down to manually relaese the door lock.
