Apple iPad (16 GB) WiFi Tablet PC Logo
A
Anonymous Posted on Aug 09, 2014
How do i hard factory reset my apple iPad 16 GB model A1395
It keeps going back to the slide to unlock i need to hard factory reset it
Michael Lei
Level 3:
Master:
  • Apple Master 498 Answers
  • Posted on Jul 18, 2019
Michael Lei
Apple Master
Level 3:
Master:
Answers
498
Questions
0
Helped
121966
Points
1736
It's simple. You can complete this task with several steps. Just follow below steps.
You are able to reset iPhone to factory settings within your iPhone. You just need to go to "Settings > General > Reset" and then choose the categories you want to reset and then apply it. If you choose "Reset All Contents and Settings", then you will get all the files in your iPhone erased.
Once you tap on "Erase All Content and Settings", you will be asked to enter your Apple ID password. Next, you will see a Popup Message informing you that All media, data and settings will be erased from your iPhone. Click on Erase iPhone to factory reset iPhone 6 Plus.
how do i hard factory reset my apple iPad 16 GB mo - img_2854-2ka233npl0212ndjbhnpio3z-3-0.jpg For more methods, check: How to Restore iPhone to Factory Settings
4 Related Answers
Jim Thomson
  • 1099 Answers
  • Posted on Feb 06, 2012
SOURCE: how to creat Apple ID for Ipade 2 16 gb
Go to https://appleid.apple.com/cgi-bin/WebObjects/MyAppleId.woa/
Jim Thomson
  • 1099 Answers
  • Posted on Mar 02, 2013
SOURCE: have just purchased an ex display ipad 4 and trying to reset to factory settings
You can do this using itunes go to http://ipad.about.com/od/iPad_Guide/ss/How-To-Restore-An-iPad-To-Factory-Default.htm it will show you how to do it. Hope this helps.
aravindnair7
Aravind
  • 15 Answers
  • Posted on Mar 01, 2014
SOURCE: my ipad got reset
Please describe your problem clearly. ;)
rsliquiran
ROWELL LIQUIRAN
  • 54 Answers
  • Posted on Mar 27, 2014
SOURCE: need to reset pass word on apple ipad
this should help you.
Use iTunes to restore your iOS device to factory settings
I took my ipad to be restored everything was cleared off. I need an ID and a password what do i do?
was it restored to factory and asking as if new set up if so use your apple id/password as before ==if this is not a new/default set up call who ever did the restore about the password and id request --if you dont have an id or password can start one as a new account ---
3answers
Were do you plug the cord in on a apple A1395 to take pictures from it to a pc
You should be able to simply plug in the 30-pin connector -> USB cable into your PC and it should show up and you can then import the images as you would for any other digital camera. This is the same cable you use to charge the iPad - just plug it into the USB port on your PC.
How to hard reset ipad air to recognise another apple id
Go to Settings... / General
At the bottom of the list is Reset
You can do a full reset from there.
A passcode got placed on my iPad by my little brother and he don't know what it is. What do I do?
It happens.)
Why not just use the ' I forgot my passcode' option..
Won't that solve it?
Sorry to be so vague. But this is my best 'shoot'. At least for now.
C.
Lookup serial numbers
it is an iPad 2 (WiFi only)
iPad 2 (Wi-Fi Only) 1.0 GHz Apple A5 apple-ipad-2.jpg Intro Date: March 2, 2011* Disc Date: March 18, 2014** Order No: MC769LL/A* Model No: A1395 (EMC 2415) Subfamily: iPad 2 Model ID: iPad2,1 Std RAM: 512 MB* Std VRAM: None Std Storage: 16, 32, 64 GB Std Optical: None Complete iPad 2 (Wi-Fi Only) Specs
lookup-serial-numbers-z4tjgmdaalvpp2apynga12w3-2-0.jpg lookup-serial-numbers-z4tjgmdaalvpp2apynga12w3-2-2.jpg
iPad vs iPad 2 vs iPad 3
How to unlock an ipad
You need to connect the iPad with an USB-cable to a computer and open iTunes software. there you will see your iPad showing up and you can do a restore:
unlock-ipad-of1o0fkyrymqaiqlgkygvvrr-3-0.jpg unlock-ipad-of1o0fkyrymqaiqlgkygvvrr-3-2.jpg Restore iPad to new factory condition Restore iPad to new factory condition
2answers
My ipad got reset
I cant unlock my ipad forgot my id can you help
You can connect your iPad to a computer and then do a factory restore to reset the device. After the restore you can set up a new password.
http://support.apple.com/kb/ht1414
Hope that helps!
3helpful
How can I tell if I have an iPad 1 or 2
Here's info from: http://support.apple.com/kb/ht5452
The (original) IPad ...
  • The model number on the back cover is:
    • A1337 on the iPad (Wi-Fi + 3G)
    • A1219 on the iPad (Wi-Fi)
  • Black front bezel
  • 30-pin connector
  • Standard SIM tray on the iPad (Wi-Fi + 3G)
  • The IPad 2 ...
    • A1397 on the iPad 2 (CDMA model)
    • A1396 on the iPad 2 (GSM model)
    • A1395 on the iPad 2 (Wi-Fi)
  • White or black front bezel
  • 30-pin connector
  • The micro-SIM tray is on the right side on iPad (GSM model only)
  • FaceTime and rear cameras
  • Not finding what you are looking for?
    Top Apple Tablets & eReaders Experts
    nexrad_chris
    NOEL
    NOEL
    John
    John
    Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
