Kenmore series 70 washer Model # 110. 247 12300 will fill with water but will not agitate. I have checked the switch and it still will not spin agitate or drain water. Any suggestions?
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Must be a bad water level switch.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
