Why does it work but is very slow?
SOURCE: problem with fridge ice maker
assuming the freezer is cold enough and that you have a valid water supply hooked up, either the icemaker is bad or the water valve is bad, best idea is to replace both.
SOURCE: Admiral Refrigerator Ice Maker
pull your icemaker tube out and see if it is frozen with ice,let me know-mike
SOURCE: Ice maker won't make ice after replacing water filter -plugged
I've had the discolored water before when replacing the filter. It normally means that there was gunk in the water line.
Do you still hear the ice maker trying to draw water in?
If not, the water pump might be burnt out.
If so, see below.
The water lines that feed the dispencer and the ice maker split after a certain point.
It's possible that the line that feeds the ice maker might be clogged. You should be able to get to it by removing a few screws and pulling off the back panel of the fridge. Then you can check them out and remove the clog.
Comment on the post if more helps is needed.
SOURCE: Admiral Refrigerator makes hollow ice
If your filter is over 6 months old, try replacing it first. Its time for a new filter anyway. Thats when I usually know its time for a new filter.
Replacement parts can be
purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts
directly.
Go through this troubleshooting help links.
This is list of refrigerator problems,
which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly
in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on
refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
