Thanks The problem I’m having is every thing works but the spin cycle! Motor, coupling, agitator, pump, turns runs during wash and rinse cycles. The spin cycle makes noise during turning of motor.
Hello. I'm a little confused at the description of the problem. You indicated it, "will not agitate during wash cycle or spin during the spin cycle." But later in your description you indicated, "It will however, drain and spin after wash cycle and during the rinse cycle." I'm not sure if you description was an error but it sounds like you will need to replace the coupling which is part number 285753A.
Your main switch needs replaced. The motor that drives the switch operates because it goes through the other cycles, so the switch must be bad. murf427
What made you replace the motor? Sounds also like a transmission problem. You motor reversing in spin but gears for agitate stripped in gearbox. Double check motor/coupling alignment. Pull the motor back off and turn the gearbox drive shaft both directions. One direction makes the basket turn, the other direction makes the agitator turn. If the agitator does not move, the gear case is bad.
Sounds like you motor coupling has broken. The water pumps out so that tells me the lid switch is fime and motor is fine. The drive coupling mounted between the tranny and motor is probably broken I have a page with pics and movies to give ya some ideas what to do. HERE
Looks like the bearings may have failed. TURN OFF the POWER and try and rotate the agitator/tub by hand. If it is jammed you should investigate why. Possibly caused by bearing failure or something wound around spindle.
Take care and do not attempt to investigate the problem without first disconnecting from the mains!
hi thanks for the question i dont know the model of your washer but i think yours is a direct drive no belt you have a motor drive coupling which is located between the motor and transmission replace that part thanks the appliance doctor
