After installing mysql,black screen ask to enter a password.After entering the password I press enter key,then the black screen dissapears..
SOURCE: FORGOT ADMINISTRATOR PASSWORD
I CAN'T CHANGE ADMINISTATOR PASSWORD IN RUN COMMAND
IF I TYPE NET USER ADMINISTRATOR * IT ASKING ENTER NEW PASSWORD I TYPED PASSWORD IT ASKED RETYPE PASSWORD I WAS TYPED THEN IT SHOWS ACCESS DENIED PLZ HELP ME
SOURCE: getting a blue screen stop error, but cant log
Please try to start from the beginning and reformat the hard drive by shutting down the system with the cd drawer open. Then insert the windows disk and turn on the pc then the drawer closes and when it tells you boot from cd press enter. Then windows will load. It will give you a couple of options. Always choose format partition. Then you should not have any problems. Unless your hard drive is bad.
SOURCE: How to reset your lost windows password using a CD/DVD or usb fla
As far as I know there a are a lot of ways to solve your problem and the easiest one of them is to use program designed to see to such problem!
And I have tried many of them, according to my experience, I recommend you the password recovery bundle which not only can recovery your windows password but also other files' password.
And I google the address for you. it is http://www.recoverlostpassword.com/products/passwordrecovery.html
Wish you good luck.
SOURCE: when power up black screen
Just hit enter, password is blank.
Testimonial: "enter did not work but was finally able to restore system to factory settings. Thanks!!"
SOURCE: i kept password for my administrator account..but
click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password
hope this helps
