Upgraded to Windows 8.1 Pro. Now the error code says to activate windows with no (KMS.) Also Product Key shown is not standard 5/25 Product Key. Build 9600. Asking for diff. Key.
Hey buddy, I was also facing the same problem in my laptop recently. I have tried many things but nothing was working and I was very worried. Then, I was researching one day online then I came across an article. In the article, they have given few step by step instructions I followed all of them and surprisingly my problem got resolved. So, I can describe all the steps here.
You can visit that blog and easily fix your problem. Just follow the blog link - https://www.microsoftwindowssupportnumber.com/blog/fix-activation-error-code-0xc004f074-windows-8-8-1/
SOURCE: windows vista activation problem
if you purchase the software all you have to do is call microsoft and have them give you a new key. If you use a crack it will only last till microsoft sends an update to fix the crack then your back at square one.
SOURCE: WINDOWS XP SP2 PRODUCT KEY
Insert the XP CD into your computer, after it autoruns click explore.
go into the i386 folder and find UNATTEND.txt, open and find (you can use alt+f) the line ProductKey. The product key will be in right there.
SOURCE: i need windows vista ultimate activation product key
try this..
6F2D7-2PCG6-YQQTB-FWK9V-932CC
2QBP3-289MF-9364X-37XGX-24W6P
SOURCE: windows activation error code 0xC004F058
Quick search got this answer:
Step set #1
1) Open Internet Explorer
2) A Browser will open, type: %windir%\system32 into the address field
3) Find the file cmd.exe
4) Right Click on the cmd.exe and select Run as Administrator
5) Type: cscript slmgr.vbs -rilc (It may take a long time for this to complete, please be patient)
6) Hit the Enter key
7) Reboot 2 times
Step set #2
1) Open Internet Browser
2) Type %windir%\system32 into the browser address bar.
3) Find the file CMD.exe
4) Right-Click on CMD.exe and select Run as Administrator
5) Type: net stop slsvc (it may ask you if you are sure, select yes)
6) Type: cd %windir%\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\SoftwareLicensing
7) Type: rename tokens.dat tokens.bar
8) Type: cd %windir%\system32
9) Type net start slsvc
10) Reboot Twice
11) Windows Vista may require you to enter a Product Key [use the Certificate of Authenticity (COA)] SLP Product Key found on the sticker on the side or bottom of your computer and activate. Use the Activate by Phone method outlined below.
From the Desktop:
a) If you have access to the Start button: Click the Start button, and type in "slui.exe 4" in the search field and then press the "Enter" key. This will bring up the Activate by Phone dialog window. Follow the steps provided by the window. The phone activation process should only take about 6 minutes.
b) If you do not have access to the Start button: Reboot and login to Vista, a dialog window will come up. In that window, click the option "Access computer with reduced functionality". Once you do that, Internet Explorer or Firefox browser will open. In the address bar type "c:\windows\system32\cmd.exe" press enter, a new window will come up, type: slui 4 and hit enter and follow steps to Activate over the Phone.
This all is if you have a true bought copy of Vista. If you have a pirated version, Im sorry to say I cant help.
SOURCE: Error Code 0xC004E003
you have the correct product key, but you have to try entering it again to reactivate Windows Vista. To do this, follow these steps:
Note Use your original product key.
