My washing machine works fine but there is water underneath on the left hand side that leaks out not sure where it come from the hose is connected on the top. Any idea on what it could be and how to fix it?
If its leaking during the fill cycle, its one of the water valves (solenoids) or associated hoses, loose clamps, etc. If its leaking during draining its the drain hoses, pump, clamps etc. Easiest way to tell. Pull it out, if you can remove the back, run it and look for the leak. Just don't touch anything while its running, you don't want to lose a finger or get electrocuted.
SOURCE: water leaking from spin dryer
sounds like the seal on the tub is shot youll need to replace it (easier to have repair shop do it unless your real couragous)
SOURCE: water is coming out from underneath the washer during operation.
did you check your inner door seal.If it is leaking will appear to be leaking everywhere
SOURCE: leaking from inside door
It's located here, just download and save.
http://miele.com/manuals/before_download.asp?id=164&bhcp=1
SOURCE: my front loader washing machine
(Check this first- it's a common problem!)
I suspect that it is the conditioner/softener tray which needs a thorough clean, paying particular attention to the sentences in BOLD
Remove the complete drawer. To do this you will have to do one of the following-
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube but on others the cover is part of the tray's plastic top. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
