1 Check the fusing unit for proper installation and correct as necessary. 2 Check the connector between M3-PRCB CN2 for proper connection and correct as necessary. 3 Check the connector of M3 for proper drive coupling and correct as necessary. 4 PS37 I/O check, sensor check. 5 M3 operation check PRCB CN2-9 (REM) PRCB CN2-12 (LOCK) bizhub C554 22-J bizhub C454 21-J. 6. Replace M3. 7. Replace the fusing unit. 8. Replace PRCB.
1 Turn OFF and ON the power switch. 2 Check the connector between M3-MFPB P101 for proper connection and correct as necessary. 3 Check M3 for correct drive coupling and correct as necessary. 4 Check the connector between CIS-MFPB P102 for proper connection and correct as necessary. 5 M3 operation check. 6 Change M3. 7 Change CIS. 8 Change MFPB.
Unfortunately not. Once it has been updated, there is no way to downgrade it. You can check with the makers of the M3 card to see if they've released a new firmware, however, that counters the newest DSi version.
sounds like you have a faulty crank angle sensor or cam angle sensor or both. try replacing them one by one or take it to a workshop with a diagnosis tool to verify.
