All of a sudden the juicer would not work in juice mode but will work in rev mode> It was fine one day and the next day it would not turn on
Check the user instructions for the Omega, common issues are listed there. If you don't have this manual somehow, download it here: http://bestpressjuicers.com/omega-j8005-review/
Flip it over and hit the reset button, if there is one. If not, then make sure that it is put together properly, mine will do the same thing if the pulp collector is on wrong. or if you overheat it, then let it set and try to reset it.... hope that helps.
Same thing happned to me (reverse but no forward) --- what worked for me was when I tried clicking on/off button multiple times quickly (5 - 6 times ) it suddenly started woking (forward) and then continued working Ok after shutting off)
I tried the suggestions above and nothing worked. I put a drop of sewing machine oil on the switch, left it alone, came back and switched it back and forth a bunch and VIOLA! it worked again!
My Omega just goes on reverse. Nothing works and no reset fuse button. help.
