Dometic Rooftop RV Air Conditioner Logo
Lee Cantrell Posted on Jun 30, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the EE message on the DuoTherm Comfort Control Center?
Anonymous
Level 2:
Novelist:
  • Expert 127 Answers
  • Posted on Jul 04, 2009
Anonymous
Expert
Level 2:
Novelist:
Answers
127
Questions
Helped
81617
Points
308
It means that an error has occurred. If you have a 4 button comfort control. Follow these steps to reset:
To initiate a RESET, do the following in the order
listed:
1) Turn control on to ensure annunciator data and light are present. If data and light are present, continue to next step. Depress MODE switch to activate annunciator light.
Simultaneously depress the bottom two buttons (temperature UP and DOWN) and hold.
While holding these buttons down, depress the MODE button once and release.
Release the two buttons previously held down. Depress the MODE button once again.
At this time the light should extinguish, and the mode should register “OFF”. If not, repeat these steps.
Retest system ensuring that all functions are present
and operational.
If you have the five button comfort control. Turn the unit off and hold down the mode and zone buttons together. While holding them down, turn the thermostat back on. Hold the buttons down until an FF appears on the screen. Release the buttons and the display should return to normal. If not, try it again.
  • Anonymous Apr 19, 2013
    Meenn... it work like a champion... i have a 5 butons comfort control that have the EE code... now is working thanks to you...
  • spark
    spark Apr 25, 2019
    can you change a 4 button to a 5 button?
Warren Brewer
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 23, 2015
Warren Brewer
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5834
Points
Perfect solution to remedy the problem I was having. Thank you!
Flashing code ee
sounds like defective t-stat or it needs to have time and setpoints reconfigured
3helpful
Comfort control center not working properly
You need to check the cable that connects the Comfort Control to the upper unit. This cable has four wires and should have continuity through all wires. If there is a break in one of the wires or a short, it will cause the CCC to fail and report an error. If all this is fine, then you have a bad control unit in the main unit. Try unplugging the rear unit from the control board and then resetting the Tstat, if this works, then there is a communication problem between the front AC control board and the rear AC control board or the rear control board is bad. Check the cable between the front and rear AC for OK. If it is alright, then you have a bad control unit in the front unit.
Another quick check is to remove the inner shroud from the front unit pull down the control box. Remove the access cover and view the dip switch panel located inside. It should be labeled Zone 1 Zone 2 etc...try turning off Zone 2 and furnace and resetting the tstat. If this works then turn zone 2 on and reset the tstat. If this is ok, then turn the furnace on and reset again. If this works, then all should be ok. If one of these fails, then you can pinpoint the problem there and move forward.
Hope this helps,
Jeff
Rate me please!!!
1helpful
There appears to be a problem with the thermostat/control panel. It won't turn on/off with out removing power. Once turned on, cannot adjust temp or mode or anything.
What type of Thermostat is this? If it is a Comfort Control Center, four or five button, then turn off the thermostat, hold down the mode and zone buttons at the same time and turn the tstat back on. When EE appears on the screen, then release the button and see if it begins to work. If not, then we need to check the control unit in the AC. Hopefully it is just a simple reset.
I have a dometic dou therm roof mount a/c model number 59136.331 with a comfort control center 3109228.001. I get an error code ee and have no information as to what this code is this is the only thing...
The thermostat needs to be reset. Turn it off and hold the top and bottom buttons in at the same time and turn the thermostat on. In a few seconds will read FF and you should be good to go.
2helpful
2answers
RV Dometic AC Comfort Control Double EE Problem
I have a dometic duo-therm. The unit works great and fan blows strong and both high and low work., but air is coming out of the ceiling unit rather than the duct work. The bedroom unit works OK, but the air is strong out of one duct, and not much comes out of the others. The front unit only has air coming out on the A/C unit and none out of the ducts.
Comfort aire A/C Rads 101-A EE light
Possible faulty control electronics. Call a repairman.
Top Dometic Heating & Cooling Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
