Model 2699w
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
SOURCE: defrost timer location for a amana model SR25F1L
part number (d7004112), its located under unit, remove back panel should be mounted to a metal plate along side compressor
SOURCE: Defrost timer sticking
Your model doesn't have a defrost timer. Everything is controlled by the main motherboard in the back. The ONLY way to get an acurate diagnosis is to call GE FActory Service at 1-800-432-2737. There is proprietary software and the tech will be able to plug in a laptop to your refer to find out what is going on. No other companies have this or have access to this software. By the way that deforst thermostat you think you found isn't what you think it is. It looks like one but it only a saftey device. Trust me...!
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
SOURCE: Where is the defrost heater timer located on an
It is located behind the lights under the light cover
