SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
SOURCE: amana ref mod.drb2201cw I need to
you left the chat but if you want to see a view of it go to www.apdepot.com enter the make and your model number and you can see the timer there
SOURCE: defrost timer location for a amana model SR25F1L
part number (d7004112), its located under unit, remove back panel should be mounted to a metal plate along side compressor
SOURCE: Defrost timer sticking
Your model doesn't have a defrost timer. Everything is controlled by the main motherboard in the back. The ONLY way to get an acurate diagnosis is to call GE FActory Service at 1-800-432-2737. There is proprietary software and the tech will be able to plug in a laptop to your refer to find out what is going on. No other companies have this or have access to this software. By the way that deforst thermostat you think you found isn't what you think it is. It looks like one but it only a saftey device. Trust me...!
SOURCE: Maytag PBF 2255 HEW refrigerator defrost timer location?
These look like schematics that might help you.
http://www.partselect.com/AdvancedModelSearch.aspx?ModelNum=PBF2255HEW&mfgModelNum=&fkMfgID=1
