Compressor makes noise and goes on and off constantly
just installed a new Danby DAC8008EE window AC and it has two problems: 1) it makes a relatively annoying vibrating sound when the compressor comes on; and 2) the compressor only stays on for about 30sec - 1min before going off again and then on again after 3min. This is quit annoying because the noise level changes from quiet to annoying vibrating sound every 3 min. When I removed the chassis from the cabinet in order to install the cabinet in the window (as indicated in the instruction manual) a rectangular block of green dense foam was just lying on the floor. One side of the foam block is tacky like it is supposed to be stuck somewhere, but I am not sure. I have tried to call the Danby customer service number, but it is constantly busy.Any help would be appreciated.Thanks,DG
  • Gary Hudson Sep 22, 2014
    call the better business beau.
  • Anonymous Jul 04, 2017
    move thermostat sensing tube farther away from cold end of coils,
  • 8,220 Answers
That foam block is an anti vibration dampening device. My guess is is goes up against the underneith od that compressor. The real problem is with the short cycling compressor. I would return that piece of junk.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Jun 30, 2009
    Sergeant:
  • 317 Answers
First of all, stop running the unit until the problem is recognized. You could void the warranty. Since you are obviously not an a/c man get some help. The loud noise could be coming from packing material that was not removed.
Posted on Jan 22, 2015
    New Friend:
  • 60 Answers
If its new make sure you have removed all the transport supports
Posted on Oct 07, 2014
6ya staff
SOURCE:
4.7 cu ft chest freezer dead
Compressor not starting, usually cheaper to get new chest freezer, rather than replace compressor
Oct 11, 2015 | Danby Freezers
Possible a/c problem, squealing noise constant, but gets better when a/c is turned on.
You did not give the make model and year, and I did not get all of the story.
Are you saying the noise goes away when the ac is on, or off ?
Dec 20, 2012 | Cars & Trucks
I have a periodic clicking noise while driving my 2009 MKS Lincoln. Anyone have this happen?
The most common cause of clicking (under the hood) while driving is an undercharged AC system. The sound is the compressor constantly turning on and shutting off. The problem could also be related to the temperature control panel which could constantly call for the compressor to turn on and off.
Jun 02, 2011 | 2009 Lincoln MKS
My window air conditioner is making very loud noises and it is not dripping water outside
No condensation means no freon flow in condensor which sounds like bad compressor which would account for the noise. Replacement would probably be most economical way to remedy.
Aug 12, 2010 | Goldstar KG6000R Window Air Conditioner
Make make a labor some noise at some time , compressor starts and
I have the same problem....throw this unit out and never buy Danby....shame on Danby for selling junk....
Jul 21, 2010 | Danby Portable Air Conditioner
Danby microwave does not heat food and makes loud constant noise
IF the noise is a sound coming from the oven area, its the megatron tube. Typically, replacing the megatron tube is more expensive than replacing wiht a new unit and a new warranty.
Nov 06, 2009 | Danby DMW112 Microwave Oven
New unit has loud noise & doesn't drain. Too late to return!
drain line kinked? trying to diagnose a noise problem over the inter net really hard . could be compressor
Jun 17, 2009 | Danby Portable Air Conditioner
Danby Air Conditioner
I have the same problem with my Danby AC unit...every 5-20 seconds it makes a god awful clicking noise...Make me wanna cry
Jul 09, 2008 | Danby DPAC8020 Air Conditioner
Heating & Cooling Logo
63,232 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Marvin
Marvin
john h
