My tablet will go to the loading screen then it will freeze
YOU HAVE TO RESET TO FACTORY SETTINGS !! TRY THIS:
How to Factory Reset Kurio 4s Tablet
Hard resetting is other name of Factoryresetting. It will be the only option for thosewho want to format the tablet. It has to be performed when there is no other option to boot the tablet. Through this procedure, user can wipe off all the files i.e. data stored on the tablet. Along with the data, the malicious programs which are making the tablet to hang will also be wiped off. So the tablet would be afresh and will be new to use.
Kurio 7 tablet can also be reset as like any other tablet. This tablet runs on Androidoperating system and hence the procedureof resetting this tablet is similar to that ofresetting any other Android tablet. When you want to reset this tablet, you have to hold the power button to turn off the device. Now you have to turn on the device by holding the power button and also the volume up button simultaneously. When you hold these two buttons simultaneously, you will be able to get a new menu. In this menu, there will be option for resetting the tablet.
You have to select this option for resetting the tablet. This will ask you whether you want to confirm the reset of the tablet or not. If you confirm it, the data stored on the tablet will be wiped off and the tablet gets formatted. Now, the tablet will reboot automatically. After the reboot, you can notice that your tablet will be afresh and will be similar to the time when you have purchased it.
Make sure to take proper backup of the data present on the tablet before you chose the option of factory resetting or hard resetting. Take a copy of all the files in to memory card and remove it before resetting. In some tablets, there will be option of backup of files through syncing. If your tablet is having such feature, make use of it to ensure the safety of data.
SOURCE: Why won't my tablet let me logout of facebook?
Go to settings, applications, then find Facebook, click it, and click Stop or Close. That'll take care of it!
SOURCE: my cruz tablet 103 won't keep app open, it just reverts to home page. Any suggestions?
You need to update your tablet, or update the programming on your tablet. Apparently all the android 2.2 tabs are considered "legacy" models and don't support the newest google and java script. Since this is what the net primarily uses, those of us with the Cruz are hosed.
