My computer was fine by yesterday and today I opened it and accidentally closed the lid when I was turning it off. I turned on the computer again 5 hours later and it shows a black screen with the words 'PCI Express Error' Can you help? :(
SOURCE: Screen stays black after laptop comes back up from hibernation
Its software,, format and reinstall windows
SOURCE: PCI Express error
make sure that the PCI Card is firmly fixed at its slot and lets notice if there will be a change..
If there is non then i guess you will have to swap the PCI card with a good one..
Please be very cautious when doing this or you can let an expert handle it for you..
I will love to hear the results.
Thankx
SOURCE: Screen turns off.. (go black)
i can give u some tell tale signs also
boot your comp in bios if it goes off wd in 10 min
the mother board needs to be replaced pls contct manu
if not needs to perform recovery
buit as u said tht it is warm,ing
it needs to be benched
SOURCE: Hp dv5000 Screen blacks out
sounds like the backlight is going out do me a favor turn it on and put a light source next to the screen if you can see everything on your screen then its the backlight
SOURCE: Dell Inspiron 1300 - When I re-open the lid,Screen stays Black !
Your laptop either goes to hibernate or sleep mode when you close the lid. Then, when you open the lid up, the screen is still off because your pc already hanged/froze and could not wake up at all (usual problem in vista). Off course, hard shutdown would fix it. But actual fix is under power options on your control panel. Check your current scheme and edit it. There are options there that you can select to "do nothing when closing the lid"
Hope this helps
