SOURCE: Bosch nexxt 500 plus dryer does not heat up. I
If you have a gas dryer.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
SOURCE: bosch dryer has pwr but not turning on
Unplug everything, remove the lid (only two screws) and check if the belt is still there around the middle of the drum. If the belt looks good then the problem is prolly the broken-belt electric switch that has tripped. That's described elsewhere here on Fixya. Did someone put in a mess of soaking wet clothes!?
SOURCE: Where is the reset button located on a bosch vision 500 series electric dryer? Model # WTVC533045/09
There is an e-how here
How to Reset Bosch Dryer eHow
that should walk you through it.
Good Luck!
