SOURCE: Whirlpool duet Front Loading Washer
go over to the end of cycle button and hold in for 3-4 seconds and you have it fixed
SOURCE: Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
SOURCE: washer is stuck on control locked
Press & hold 'end of cycle' at right of panel for 3 seconds. The light will come off.
And rate me plz....................
SOURCE: Duet GHW9150P Front Load Washer: whirlpool washer says control locked, how can we f...
Press and hold "end of cycle" button for 3 seconds, on the right side
of panel. This is the child lock feature, do it again & it locks.
If
helped, pl rate me good!!
SOURCE: Whirlpool Duet washer stuck in "control locked"
Press and hold the end of cycle button for 15 seconds this should clear it.
Control locked
Hello & Welcome to FixYa
This is a common issue with Whirlpool Duet washer however;
your whirlpool duet washer needs a reset to resolve the control lock problem.
Press and hold the END OF CYCLE/CYCLE SIGNAL button for 15 seconds to reset
the control. Please get back to me if you have any other questions.
Kevin
Kevin
Kevin
Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to reset
Kevin
however, your whirlpool duet washer needs a reset to resolve the control lock
problem. Press and hold the END OF CYCLE /CYCLE SIGNAL button for 15 seconds to
reset the control. Please get back to me if you have any other questions.
Kevin
Kevin
Your whirlpool duet washer needs a reset to resolve the control lock problem. Press and hold the END OF CYCLE button for 15 seconds to reset the control. Please get back to me if you have any other questions.
Kevin
