Question about Exercise & Fitness
Does the 3500R nordic track need batteries? - Exercise & Fitness
    Novelist:
  • 176 Answers
Depending on the model. Some have batteries, other have power provided by the Treadmills transformer inside the console. If you can locate the battery holder/box behind the console, then the console works is not connected to the electricity supplied by a small transformer in the console. Add the batteries. If there is no battery compartment then it runs on electricity. Remember that treadmills are delicate equipment that run for years with proper care. Always lubricate the running belt with a good quality silicone spray. To avoid making a mess on the floor or carpet, spray the silicone on a lint-free cloth to give a light soak outside the home and then go back inside and lift the running belt high enough to be able to wet the base with the cloth. Run the belt a minute, then swipe the cloth a second time. Next check with your fingers or hand if the base feels wet and smooth, suggesting that the base is now lubricated, before using it. Do not apply too much as the belt can spray traces of liquid similar to a car tire spraying water on a wet road. Hope it helps.
Posted on Aug 01, 2014
Anonymous
SOURCE:
Tim F
  • 103 Answers
SOURCE: Calibration Mode for nordic track treadmill model
Hello there, The calibration mode for a nordictrack is as follows.
With the safety key out, hold the stop and speed up arrow at the same time while inserting the key. Release the buttons. You will then be in diagnostics.
You then press the stop button one time.
If you are trying to calibrate the incline you just need to hit the incline up button and the machine will do an incline calibration. The unit should go all the way to the top and return to the bottom when completed.
If you need to calibrate the speed you will need to press and hold the speed up button on the console until the display reads 85. The machine should then be running at its maximum speed (either 10 or 12 mph depending on the unit)
The display will show a speed on the console and should be within .3 of the maximum speed.
If it is not then it will need to be adjusted using a potentiometer on the control pwb.
To access the control pwb open the hood cover. Should be 3 screws in the rear of the cover and 2 screws on the bottom of the unit.
Once inside the cover locate the control pwb. On the control pwb there will be a yellow/orange potentiometer. This is the adjusting part.
Use a non-metallic phillips head screw driver to adjust the potentiometer either clockwise for faster or counterclockwise for slower.
Hope this helps!
Good Luck! Tim
Posted on Jan 13, 2010
Testimonial: "Although I haven't attempted this solution, but it makes perfect sense and will attempt it as soon as I get back to the treadmill - Thank you"
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: manual for a Nordic Track Personal Performance
Go to iconservice.com click on to manual Input manufacturer : Nordic Track then model # NTL349050 and you manual await you.
Posted on May 15, 2010
Anonymous
SOURCE: Belt slipping on Nordic Track c1900
My belt is slipping I tighten both alan head screws to the max roughly 7 turns and still have the broblem
Posted on Jul 10, 2010
Anonymous
SOURCE: need manual for nordic track walk fit 5000 1995
I can't help with the manual. But, if you reach under the area where the readout is, push up on the cord or any of the opening underneath the display will pop out. You should be able to find the battery compartment. The unit uses 2 AA batteries. If you find a manual, let me know.
Thanks.
Posted on Jul 26, 2010
ercupa190
ernesto cuadra
  • 12223 Answers
SOURCE: Nordic track Ski
Dear Sir:
The best way is you go to the next web page:
www.nordictrack.com you must give serial number+modell
whoever i will give another alternative.
www.fitnessrepairparts.com
www.gympart.com
Posted on Nov 13, 2011
My Nordic track elliptical audio strider 800 console does not work. I have changed batteries and I have purchased the adapter and still does not work. What can I do?
Better to buy a new console. It would be difficult to repair the existing console.
I'd you wish to get some details about elliptical repair then check the below added link.
http://electro-medical.blogspot.com/
Jul 20, 2016 | Nordic Track Exercise & Fitness
I need BC 887 manual
[DOC]Nordic Track Achiever Manual
188.166.107.131/nordic-track-achiever-manual.doc
... owners manual pro achiever etc ebay , nordic track achiever bc 887 manual ...nordictrack treadmill achiever reviews viewpoints , nordic track skier exercise ...
[DOC]Nordic Track Skier Manual
188.166.107.131/nordic-track-skier-manual.doc
... treadmill manual google sites , ntl nordictrack nordic track c manual sears , nordictrack ntl 1 user manual pdf download , nordic track achiever bc 887 manual ...
achiever bc 887 Treadmills Questions & Answers - Fixya
www.fixya.com > Forum > Tags > achiever bc 887
Treadmills achiever bc 887 questions and answers. Ask your ... Where is the ENTER button? please follow the instr.manual if you do not have it download it from ..
Jan 14, 2016 | Exercise & Fitness
My tread mill belt will not run. it suddenly stopped working when i stood on it. there seems to be power to everything else
LUBE the deck belt with grease or WD-40 o any silicone lube.
try to loose the belt deck in the way that when you lift with you finger will be 2" max. See the drive belt , must have a deflection with your finger 1/4" aprox. Of course time to maintenance motor: lube the bearing or replace, and the carbon brush. Lube the deck bel 1time every week.
However you must test the voltage to the terminal to the motor from 0-180 Vdc, if NOT replace the Motor control Board
Feb 08, 2015 | Nordic Track Nordictrack 3500r Treadmill...
My nordic track 2000 lights come on but will not respond when pushing the buttons
adjust the reed switch, clean it , test for open or faulty, tight the connector very well, see the diagram attached, Replace batteries too
Jan 09, 2013 | Nordic Track Nordictrack Exp 2000...
Just purchased the nordic track 2550 pro treadmill and was wondering if you had to lubricate the belt, i was told that it was self-lubricating and never needed oiled.
You do not need to lubricate the belt, unless you speek with or read something from Nordic trac. Oiling wont hurt anything, but is not needed.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Dec 29, 2010 | Nordic Track NordicTrack A2550 PRO...
Manual for a Nordic Track Personal Performance
May 13, 2010 | Nordic Track NordicTrack Professional...
Looking for manual for basic nordic track -- basement was flooded
Go to www.iconservice.com and Input Nordictrack Pro and you will find a manual for your unit
May 05, 2010 | Nordic Track /proform Treadmill...
Nordic Rower replacement wheel
Nordic Rowers were made by Water Rowers, which still exists and sells parts.
Aug 18, 2009 | Nordic Track Exercise & Fitness
Manual
download it from the nordic track website.
Feb 01, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
46 people viewed this question
Top Exercise & Fitness Experts
Treadmill Repairs...
Tom Chichester
ray gallant
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
