SOURCE: Kenmore Washer 110.26912690 series 90
Hi Norm. Welcome to FixYa.
The first thing to check with the kind of symptoms your machine exhibits is the operation of the lid switch. Make sure that the pin/plunger on the lid itself has not broken off, and check the actuator lever on the switch itself. It is REALLY common on your model for the actuator arm to break off or crack, and this will cause no spin/no pump problems. Your machine is built by Whirlpool and the part number for the switch assembly is a 3849238. You can get it at any local whirlpool parts center in your area.
I hope you find this info helpful and thank you for allowing us to serve you.
Happy New Year from the FixYa crew!
SOURCE: Kenmore model 110 washer will not drain at end of wash cycle
It could be the lid switch or the timer.
SOURCE: Kenmore HE2T F20 plus Water leakage when tub starts to fill
Have you read by advice on how to diagnose this problem? Click on the following link:
http://www.fixya.com/support/r1491905-f20_error_code_whirlpool_duet_kenmore
If you HAVE water entering the wash tub, first verify that you do not have a siphoning condition. This is where the drain line does not have the proper air gap to drain properly and creates a vacuum on the drain line. This will cause drain problems and may prevent the washer from filling all the way. Or, you may have trouble maintaining the water level. When you stated you had water leaking, is this a visible leak? Or, do you have water slowly draining from the tub? Double check your drain line to be sure.
Next, check the drain pump to ensure it is not clogged or obstructed which minimizes drain flow. Also, make sure the pump is running. Remove the access cover and clean out the pump reservoir. In addition, check the drain line from the bottom of the wash tub to the inlet side of the drain pump. I have personally found small articles of clothing stuck in this line, preventing drain flow.
Read through the link thoroughly. If you require additional assistance, please let me know before rating the solution. I hope this helps you.
SOURCE: kenmore HE2T front loading automatic
"F22" is a door latch error. It can mean any of the following:
1. The door latch mechanism is broken. Inspect the door latch to ensure it is intact and not broken. Verify the electrical connections are making good contact.
2. The door latch hook (located on the door) is broken or worn. If the latch hook is damaged, it may not allow the door latch to engage and lock properly.
3. The interconnecting wiring between the Central Control Unit (CCU) and the door latch are loose, broken, or not making good contact. The CCU is the main computer for the washer. You will need to remove the top panel of the washer in order to access. Simply remove the retaining screws located in the back of the washer and the panel will slide back, then lift off.
4. Defective CCU. The CCU controls nearly all the functions of the washer, including the door latch. If the CCU fails, the proper lock/unlock signals do not get sent to the latch mechanism.
Determing how to troubleshoot the CCU and Door Latch is in the technical data sheet included with your washer. The tech sheet is located behind the lower toe panel directly below the door. If the tech sheet isn't behind the toe panel, it will be affixed to one of the interior cabinet walls. I do not have the procedure memorized, but there are some tests you can try to determine if the problem is the CCU or latch.
If you determine the latch needs replaced, the following link may assist you:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
The procedures I provided are for Kenmore Elite series front loaders, which are the larger cousing to the HE2. The steps are nearly the same except for how to remove the door gasket from the front facing of the washer. The HE2 models are glued on instead of using a wire hoop (unless yours is a later model and has been modified). You can use a metal putty knife to carefully peel the gasket loose and reseal it when completed. A good appliance gasket cement (found at any appliance parts retailer) will work. You can also use a plumber's sealant. Just make sure you use a pliable rubber cement. Do not use super glue.
Some prefer to try to work through the top of the washer and avoid removing the gasket. This may be possible with the larger top loaders, but the smaller models are usually a bit more difficult to access.
Replacement parts can be purchased on line at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
If you have any questions, please let me know. I hope you find this information helpful.
SOURCE: kenmore he2t error code 21
F21 is a long drain...it is taking too long to drain..you have a something slowing down the drain.. you can remove the bottom panel and clean out coin trap... if there is nothing then you may have another problem... but this is the most common problem..
