Fluval Hagen M50 Submersible Aquarium Heater 50W Logo
Michael Coppinger Posted on Jul 29, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do set the temp on a 15 gallon tank - Fluval Hagen M50 Submersible Aquarium Heater 50W
Richard Lindsey
Level 2:
Champion:
Habit-Forming:
  • Expert 211 Answers
  • Posted on Jun 23, 2017
 Richard Lindsey
Expert
Level 2:
Champion:
Habit-Forming:
Answers
211
Questions
0
Helped
101637
Points
431
Leave the heater unplugged in the aquarium in for several hours.Then plug it in briefly and see if the neon bulb lights up (sort of an orange color). If it is on, turn the temp set knob counter clockwise until it goes out. Then turn the knob clockwise slowly until the light comes on again. Now your heater is set for approximately the current temp of the aquarium water. Now adjust the knob in very small increments, waiting hours between adjustments until the water is at the temp you want.
1helpful
How many gallon gas do the gas tank hold?
Fill it with the gas can and then go to a gas station. Your gas can can't be much bigger than 5 gallons, there's very few that are larger because they get heavy. Your gas tank is vastly more than 5 gallons, probably 15 or more in an Envoy.
I have bought a 20 gallon tank for my two bettas has everything I need in it. With divider right now there in separate 1.5 gallon tanks without heaters and one of them has filters am I able to switch them...
If all you have in a 20 gal tank is two bettas, I wouldn't worry about the cycle period. I would do a partial water change every week or two though.
2answers
My family is moving in...how do i increase hot water availability?
large water heater, turn p the themo stat to a higher setting ( watch for burns with young childern and older folks)
or the best install a tempering valve. this valve mixs hot water with cold water before it goes into the building.
Again if you have young ones or old people they can burn faster than any other group.the best is a larger heater for the DIY person.
Thanks Tom
4answers
How many miles do u get for a full tank of gas on a v8
It just depends on your tank size. You probably get about 15 -18 miles per gallon. 13 gallon tank would be around 200 miles. 15 gallon tank around 232 miles.
Energy smart hot water heater not giving ample amount of hot water both elements ohm at 12.5
For images and product information
For manual
You checked ohms, did you check for 240V across lower element when lower element is turned on?
Energy smart electric water heater
has a control box on top of unit. Water heater does not have typical thermostats that can be tested and replaced. Temperature sensors located above each element send information to control box through small black and red wires. Temperature sensor sells for about $40, but there is no test listed that shows how to determine when sensors fail.
Potential problems:
-Temperature sensor is not reading correct temp
-Control box not processing correct temperature information
-Selector on control box set to 2, 3 or 4
-Thermostat temp on control box set lower than 120 degrees F
-Sediment build-up starting to surround lower element so water doesn't circulate (see if drain valve runs full-open
Can i use the timer for a water headter to trun on and off
Paragon 8145-20 is a 240V defrost timer
It is probably not best choice for water heater timer
Timer initiates defrost cycles each 4 hours.
A water heater timer should have more scheduling options.
-For example estimates show average run-time for water heater is 3 hours per day, depending on incoming water temperature, thermostat setting, and number of gallons used.
-To save money using water heater timer, you have to schedule times carefully so water heater runs less than 3 hours per day.
-Now your average electric water heater heats about 20 gallons per hour.
-Average shower uses 4-9 gallons hot water, so water heater needs to run 15-30 minutes (15 summer, 30 winter)
-Average bath uses 12-15 gallons hot water so water heater runs 45-60 minutes
-But lets say you run water heater for 1 hour and make 20 gallons of hot water. Then you take a shower, expecting hot water to remain in tank.
-Here's the problem ... cold water entered the tank to replace the shower water ... and the new cold water is cooling the rest of the tank.
-So a timer means scheduling hot water to match shower and bath events. For example taking shower and bath in immediate succession.
-Or set the timer for each individual hot water event ... for example set timer for 1/2 hour for shower, and later timer turns on 1 hour for bath, or 1-1/2 hr for 2 baths, etc
-> The flexible programming described above is not a characteristic of defrost timers.
I suggest Intermatic WH-31 240V or Intermatic T-104 240V or GE 15207. These are mechanical repeat-24 hour timers with manual override where each day has same schedule.
Digital programmable timers like Intermatic EH40 offer 7-day, 40 event programming. Weekends and weekdays can be different.
To see several box-type timers:
http://waterheatertimer.org/Boxtype.html
What psi should the storage bottle for an Culligan AC-15 water system???
If it is a 3 gallon tank the pre-charge pressure (without any water in the tank) should be 7psi, 10psi for 10 gallon tank.
RJ
2answers
Ford windstar3.8 engine MPG
15 city 18 combined 22 highway
1helpful
2answers
2000 Ford Expedition Starting problem
If the fuel gauge drops off when you are driving then its a sending unit problem that means you have to drop the tank and replace the float and sending unit. This is a common problem for alot of cars because of cheap gas. If you have to drop the tank check the fuel pump canster for dirt because of cheap gas. Replace the fuel pump strainer and fuel pump filter. If the car or truck has about 100,000 miles you might want to change the fuel pump at that time also just to cover your back. If you take it to a shop they will charge you at least $900 to start. But if you do it yourself it will cost you about $200 dollars maybe alittle more.
Top Fluval Fish Experts
Keith
Level 1 Expert
ADMIN Andrew
ADMIN Andrew
Are you a Fluval Fish Expert? Answer questions, earn points and help others
