SOURCE: need to know how fuel line end in fuel tank on a
Your Craftsman trimmer is made my Poulan/Weedeater and uses 2 different sized lines. The smaller diameter line is the fule supply line and runs from the pickup filter in the tank to the supply side of the carb. The supply side is usually the lower of the fuel nipples on the carb. Make sure to put enough line in the tank so the filter can drop to the lowest point of the tank while you are trimming. The larger diameter line is the return line, and will connect to the nipple on the carb that is closest to the primer bulb. From the factory, the return line went into the tank and had a small clear plasted connector on the end to prevent it from slipping back out of the tank. This fitting does not connect to anything in the tank, it is merely a return line. If the return line fitting is missing, just make sure to leave a couple of inches of line in the tank. If the filter is missing, you MUST replace it...it will save you from having to clean the carb out every 10 minutes of run time.
model Ge type 2
