Easy to dismantel more diffucult to built it back. Thanks to pictures, you can manage to build it back.
This pictures are useful because when you will dismantel the duax, the springs will spring without you had noticed the position of parts.
you do not need to dismantel . first remove the front grill which is held in place by screws which you are able to see. you need to get a special screwdriver for this, looks like a star screwdriver but i think it has about 6 slots. then only will you will be able to remove the speakers. if you are only removing the diaphragm , all you got to do is remove both handles and unscrew the the driver . then remove the diaphragm from the driver and replace with the new one
hello mam
please check the following
1.short circuted power cord this can be checked by disconnecting the power cord from the dryer and switch on the mains.
2.heating element is defective this can be checked externally by dismanteling by the druer.
3.dryer motor is defective this can be checked externally by dismanteling from the dryer.
my best advice is for dismanteling the elements of phone give the set to local service station because if by chance we dismantelled important elements the warranty will be void.. so better avoid this... hope i have helped you.
you must change the gasket between bottom flange and machines underside and apply Hobart mastic to each bolts, not expensive but may require some plumbing dismanteling
