SOURCE: How do I take gas tank off of a Husqvarna 125B gas
Hello . First you have to remove the 3 nuts holding the plastic back part . 2 nuts are on the bottom and one at very top of the machine .
Then you just have to remove the 3 phillips head screws holding the tank and remove the fuel line . Hope this help .
SOURCE: I have a Husqvarna 125B handheld blower, will not stay running
probable clogged screen in carb. rebuild carb with a kit. also check fuel lines and fuel filter
SOURCE: Husqvarna model 125b Hand held blower (Gas) No
If you have tried a new spark plug and you still have no spark, then your Ignition Coil, (Module) has gone bad. They aren't cheap if you buy it new. Try to find a used one if you can for around $10.
Good Luck!
Jim
1. Check the pipes to the primer bubble haven't been swapped round, as it sounds like its pressurising the fuel tank.
2. Also sounds like the fuel tank vent could be damaged, this allows pressure to equalise in the fuel tank. Generally it allowa air in but not out the tank, If fuel is exiting the tank then this could have been damaged.
