The Boiler unit is not working have it repaired, or get a new one!
Before you replace the boiler, you need to test the entire electrical line. In most cases, you will find that you have power up to the thermal fuse located in the middle of a wire attached to the top of the boiler, but no power after. In this case, you can purchase and replace the fuse (usually 229 degrees centigrade) for a few dollars.
SOURCE: Need a cap gasket for a Rowenta DG5030
I showed the part to my husband. He took it to our local Aubuchon Hardware and bought the same size gasket for 59 cents. I just tested it out and my iron works just fine now. The one from the hardware store is black, vs the Rowenta one which is green. Who cares what the color is, no one sees it anyway. However, if you have to send your machine for repair for something else, they may not honor your warranty as you've now added after-market parts. Just thought I mention that. Good luck.
SOURCE: My Rowenta DG5030 Iron will not heat; the water
Here is a tip that will help you to troubleshoot our iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
SOURCE: Rowenta Steam Iron DG5030; Iron drips water
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
SOURCE: my rowenta dg5030 is leaking at the cap
My question is what is Rowenta doing about the gasket problem. Where is the replacement.
