How to remove the back cover
SOURCE: My Kodak ESP5 keeps saying
My esp 5 gave me this same message. I'm not an expert but here is what worked for me.
I turned off and disconnected both cables (usb and power) then reconnected and turned on.
At this point it still read paper jam, so I took ink cartridges out and paper out.
I then reinstalled ink cartridges and PULLED OUT THE PAPER TRAY to it's FULL capacity, added about 5 sheets of paper, and on the main menu I chose the allignment function and printed a test page and suddenly....no jam!
Hope this works for someone. For some reason pulling the tray all the way out cleared the "jam" message for me. Now if I could just get the new ink cart to work I'd be all set! Good Luck!
SOURCE: got a paper jam how do I take off the back to fix
Log onto www.kodak.com/go/itg and follow the online steps to either resolve the issue or tell you to contact Kodak for replacement.
Testimonial: "Was helpfull"
SOURCE: My printer a Kodak ESP
If you are sure you have cleared all the paper that may have been jammed. You should have the printer replaced/repaired under the 12 month warranty, first try these steps including upgrading the firmware:
IMPORTANT: If the ink cartridges are not completely seated, a paper jam error can occur. If you have an ESP 3250 or 5250,
upgrade the firmware, then reseat the ink cartridges.
If you have upgraded the firmware in a previous step, go to Step 3 to access the printhead, then
continue the step by step solutions and repair. Otherwise do the following to upgrade the firmware:
Once you upgrade the firmware, use the following steps anytime you access the printhead or ink cartridges.
Close Window
To update the firmware go to this link and select printers>all in one printers> then your model:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=7895&CID=go&idhbx=downloads&pq-locale=en_US&_requestid=239
Thank you,
Lee
SOURCE: I had a paper jam
Click on the link below to download the Kodak ESP 3250 user manual, inside this manual will explain how to reinstall the back panel
http://www.retrevo.com/support/Kodak-ESP-3250-Multifunction-Printers-manual/id/23553bh846/t/2/
SOURCE: error code 3528 keeps coming up,telling me to
I have this printed and if you read (carefully) through the manual it tells you it doesn't like single sheets of paper. If ever my paper feeder tray runs below say 3 sheets then this error will crop up so keep it topped up with paper. The same goes for photo paper too.
Top
Paper jams inside the printer
Top
Clearing credit card-sized paper jammed inside the printer
Credit card-sized and 4" x 6" sized paper must be loaded properly. If this media is not loaded properly, it will feed into the printer and will not exit. Credit card-sized paper should only be loaded in the ASF and in portrait orientation. 4" x 6" sized paper can be loaded in the ASF or cassette. But must be loaded portrait orientation.
If credit card-sized paper was loaded in landscape orientation in the ASF and did not eject (exit), please follow this procedure.
