SOURCE: kenmore 417.29042992 front loader washer
If front loader washer quit spinning, check the wax motor switch. You can make a temporary fix by providing a short on the door lock contact. The Kenmore 417.29042992 front load washer provides a test connector that's readily accessible behind the front lower panel. Insert a wire between connector pins 1 and 2 (red and white/red color wires) and your washer should spin during the spin cycle. Hopes this helps.
SOURCE: unlock the control panel to a kenmore elite front loader
to unlock the controls
select and hold drain/spin for 3 seconds until the control locked status lights turn off.
SOURCE: kenmore elite he 4t washer
I have the he4t and everytime I wash I get an f02 error. The washer wont drain and spin unless you cancel and restart the washer. What can I do to fix this?
SOURCE: Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
SOURCE: my kenmore elite oasis washer will not turn on. I
its the power button its a common prob use a soldering iron and switch it with the load sinal button this happpens as the washer alallows moisture to get on the board as its not protected it will save u a ton of money and anyone can do it
