Disposal isnt working its full of junk how do i get absolutely all power off to it so i can clean it out and then what do i do to troubleshoot it and if i need to replace how to do that?
How about creating a compost barrel? Pretty easy, there is a site called family handyman that has a pretty straightforward plan for one. But, if you can't be bothered to do that, just google to quickly find a list of items that CAN'T go into a garbage disposal. Most garbage disposals that are installed correctly have a traditional 110/120v plugged into an outlet installed under the sink that you can easily disconnect. If it's wired directly into the house wiring, you'll need to determine which breaker in your service panel to turn off so that you don't get mildly electrocuted or chop off a hand or something. Most disposals have a small hex-shaped allen bolt hole underneath that you find an allen wrench to put in and work the disposal back and forth by hand, that should free up whatever clogs are inside. Make sure you leave some sort of screen or stopper in the drain to stop silverware or random things from falling in that shouldn't fall in like tea bags, ends of onions, tomato stems, nut shells, things that may not "shred" easily. If you need to ultimately replace it, (which is rare and unlikely), you will need to ask a neighbor or someone handy to figure it out, because not to sound like a chauvinist, but most women technically CAN do most things men can, they just don't WANT to, or can be bothered to learn or whatever else, that's why guys fix stuff and women typically don't. Anyway, good luck, I'm sure it's just a little clogged with some junk that your hands can reach in and take back out, I REALLY wouldn't worry about it being broken, I'm pretty sure it's not.
