Do I twist the blue bypass cap, or do something else? It is not budging when I twist it. I just had the refrigerator delivered and am trying to install the first water filter.
SOURCE: I can't get the bypass cap off to replace the
I just got my whirlpool fridge and I'm having the exact same problem! The blue cap appears stuck and I'm afraid I'll break it if I force it with a tool. Please post a solution if you get one - I'll do the same. Thanks.
SOURCE: Where to get bypass plug/cap for LG Refrigerator
i totally aggree bypass the built-in filter on the lg and get a universal in line filter, do the math it all most cheaper to buy bottaled water all the same taste- u still change filer every 6 months but it's 10- year not 70 - 100- ,get real....
SOURCE: I get a new 22
Here is what you need=> Maytag user Manual and in the top scroll bar go to page 13. These instructions for your model will help you very well! If you have other questions please let me know, Thanks, Sea Breeze
http://appliance911seabreeze.com/index.html
SOURCE: We have a KitchenAid Superba
Hi
These caps can be very stubborn to remove, the 'o' ring seal can almost lock it into place.
There are 2 things you can try
Switch off and unplug the fridge
Switch off the water supply and open the dispense valve
1. Use a hair drier to warm the cap, be careful as this can get very hot, you may choose to use gloves if it seems very hot, be careful not to overheat as this can distort the cap.Then twist anticlockwise and pull to remove the filter cap.
2. Put a shallow tray on the floor below the filter and cap, carefully and slowly pour hot (not boiling) water over the can then ,wearing gloves, twist anticlockwise then pull to remove the cap.
You may need to persevere if the filter has not been changed before.
Having changed the filter then plug in the unit and switch on the power and water and draw off water from the dispense valve in 5 second burst for about 2 mins to remove air from the filter and ensure that clean water is right through the fridge.
Good luck
Gordon
