SOURCE: Cleaning my self-clean oven
Turn the oven to "clean" and lock the door if the oven has a manual door lock. The oven may have an automatic timer for the clean setting. If it doesn't then you'll have to turn it off yourself in three or four hours. Don't be surprised if the oven puts out a very foul smell while it's cleaning itself as that's normal for an oven that hasn't been cleaned in so long. After it's done, wait for the oven to cool and then wipe out the ash from the inside of the oven.
SOURCE: DCS double wall oven model WOSD 230 totally dead during first self clean
let me know if you don't get the solution... thanks
SOURCE: self cleaning oven directions
Press the self-clean button. The panel becomes blank(---), then press the up arrow( ^ ). The panel will appear 3:00 (indication for the duration of self-cleaning). The oven will lock on its own and start the self-cleaning. Good luck, ya'll!
SOURCE: self cleaning oven won't start self clean mode
NO IN ORDER TO ENGAGE IN SELF CLEANING THE LOCK MUST FIRST ENGAGE. DOOR LOCK ASSEMBLY FAILURE
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
