Straight from the Kyocera service manual.
Main charger high voltage error. Five pages have been printed with the main charger output short-circuited.
Causes: Drum unit installed incorrectly. Engine PWB installed incorrectly. Defective engine PWB.
Solution from service manual:
Verify harness is not pinched in the drum unit.
Verify harness is not pinched in the engine PWB.
Replace the engine PWB.
If you have tried to repair the printer yourself, just go over the reassembly procedure, you might have pinched a wire or one of the connectors might be bent or not in properly.
Regards
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
am using koyocera ecosys p3150dn printer so my printer is not functional know in the case of (machine failure call seevice 5100:0000000 ) what is the reason & the solution ?
