I raised it almost vertical to remove and sharpen blades letting it down the shifter doesn't work
SOURCE: blades won't engage
I have a john deere 185 was mowing and my blades Quit turning with the switch still on,any quick fix?
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
SOURCE: 46" mtd 25hp riding mower. Idoling ruff...
I had a similar problem on my 42" MTD riding mower, the vent in the gas cap was plugged up. Replaced the gas tank cap and it fixed it (Lowes sells them)
SOURCE: MTD 42" CUT MOWER MODEL 42A707 TYPE 1238 01
I think either the bolt holding the left blade onto the spindle is loose, or the cup washers under that bolt are flattened or missing. As a result, the blade is slipping on the shaft and probably making a squeal or squawk. Take off the deck, flip it over, and remove the blades. Note if the bolts seem tight. And look at the washers stacked under the bolts. Replace any missing washers, or flattened cup washer. Make sure the cup washer faces the right way (hollow side toward the blade). Tighten things back up securely - it takes a hefty pull on the end of a 2 foot long wrench to get enough torque.
SOURCE: My MTD riding mower is
normally sign of a failing hydrostatic transmission. if your mower has one, start looking for a new one, mower that is as a new tranny will cost more than a new mower.
