Mtd Drive Belt 42" Logo
A
Anonymous Posted on Jul 19, 2014
My 42 mtd is chugging when i put in forward
I just replaced belt but had no problem before I did
larry odonnell
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Oct 08, 2014
larry odonnell
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
4126
Points
6
Don't know if this is your problem but here is what happened to mine..
My lawn tractor is about 10 years old. It has been generally quite reliable. However I was mowing with it one day and after 15 minutes or so it started hunting and then quit. After a few minutes it restarted and ran for a further 15 minutes. This time I disconnected the gas line after the fuel filter and nothing came out. I removed the filter and blew through it and it was clear. But no gas came out of the gas line till I pointed it downward then got a good flow. Reassembled and drove for a few more minutes and quit again. Checked the spark - good. I removed the gas line after the filter again intending to blow some air into the carburetor to clear any obstacles there except - no gas from the line. I removed the gas cap and out came the gas. The problem was the pinhole vent on the cap was plugged and not allowing air into the tank to replace the gas being consumed. Cleared that and solved the problem! Hope it helps someone else save $150 or whatever it costs to take it into the shop!
5 Related Answers
Anonymous
  • 226 Answers
  • Posted on Jun 06, 2009
SOURCE: 42" mtd yardmachine belt keeps coming off
twords the rear of the deck there are two bars with pins that hold the deck.they should have 3 or 4 holes where you can adjust the rear of the deck.check to see if there set to the middle somewhere,if so you can disconnect the 2 pins and try going up 1 hole iif that didn't work try down 1 from original point.
Anonymous
  • 32 Answers
  • Posted on Jun 20, 2009
SOURCE: MTD Yard Machine does not go forward or reverse - I replaced belt
I think that the belt is not on right. if you look at the belt diagram from the top, then on the left side then the belt is hooked up to nothing. on the right side then the belt goes through the left side of the clutch pulley.
Anonymous
  • 226 Answers
  • Posted on Jul 03, 2009
SOURCE: Deck belt
go to partstree.com click mtd,then put in your model#;then click deck assembly. it will show you your belt routing;then scroll or click the item #.it should tell you the lenth of your belt.hope this helps.please rate this;thank;s
Anonymous
  • 45 Answers
  • Posted on Aug 25, 2009
SOURCE: replace transmission belt on my 42" MTD Mower
You can download a manual here:
http://manuals.mtdproducts.com/mtd/public/list.jsp
You will need the model & serial numbers.
Anonymous
  • 169 Answers
  • Posted on Nov 25, 2009
SOURCE: MTD 42 inch hydrostatic drive lawnmower
1...first and foremost check the fluid level and top off with mobil 1 full synthetic 20w50 oil,
2...check the the engine pulley for wear
3...check idler arm spring tention.
inside yout transmission is a center pump section and swash plates and a set of 6-8 pistons , if dirt is allowed into the transmission it causes severe wear to these parts
my recomendation would be to dissasemble the transmission and inspect the pump center section and swash plates for wear....look for tiny scratches on the bearing surfaces, if it is worn then replace parts as needed. these worn parts will cause the transmission to "growl" or as you say "grind"
Mtd Yard Bug Riding Mower 500 series It was working fine now won't move in forward gear.
Question edited for full make model (what it is).
Question moved from Cars and Trucks.
Sounds like one side of the gear selector cable is slack.
https://www.google.com/search?q=Craftsman+yard+bug+500%2C+not+moving+forward
Mtd yardman differential
check your drive belts, pulley's and belt tensioner... you could of gotten better help if you would of included the model #
Dec 03, 2013 • Mtd Garden
1helpful
Craftsman 42 in Deck Lawn Tractor jerks/bucks when in forward during turns. Is there an adjustment or do I need a new belt?
Sounds like to me you need a new belt! The belt is automatically tensioned by a spring on most mowers by MTD, the major mfr for most mowers including craftsman.
Have MTD 38" mower mower
Hi there. You can go to this site and download the manual for your machine. It shows belt removal and re fitting. Just enter your model numbers in the center field and press search http://www.mtdproducts.com/webapp/wcs/stores/servlet/OwnersCenterView?storeId=10500&catalogId=20500&langId=-1 Hope this helps
FORWARD AND REVERSE GEAR SELECTION BACKWARD
Recheck your belts, does your engine have a pto
Jul 28, 2009 • Garden
2answers
I HAVE A 660 SERIES MTD YARD MACHINE 17.5HP 42
If the speed seems to be different after changing the belts, it should return to normal after they break in.
The 600 series has a top speed of about 5 - 6 MPH, see:
http://support.mtdproducts.com/cgi-bin/mtd.cfg/php/enduser/std_adp.php?p_faqid=79&p_created=1027096447&p_sid=tq2XafGj&p_accessibility=0&p_redirect=&p_lva=68&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTYsMTYmcF9wcm9kcz0zMDEmcF9jYXRzPTAmcF9wdj0xLjMwMSZwX2N2PSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PXNwZWVkIGNvbnRyb2w*&p_li=&p_topview=1
Top Mtd Garden Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
john h
Are you a Mtd Garden Expert? Answer questions, earn points and help others
