Changed the filter and water still comes out too slowly
Check the dispenser tube to be sure it is not partially plugged by taking a piece of grass whip cord and pushing it up the out spout a few times. Then try the water output in a glass so you can inspect the water for calcium deposits... If this doesn't help, check the connections at the filter to be sure that there is no obstruction at the connection between the incoming water line and the filter...
SOURCE: ICE MAKER and Water Dispenser
very likely a partially clogged filter, but not sure why no light.
SOURCE: Water dispenser slow
you fitler most likely will need to be replaced post the model # and i will get the the replacement part number you need to get
SOURCE: water dispenser is working very slow the water is flowin very slow.
is the s water holder frozen?
Look behind the lower left prodcue box
if not it could be the despenser valve not
opening all the way
Is the ice maker working OK?
SOURCE: Water dispenser slow flow after filter change
I had the same problem when switching to Pur filters. There are two curved wedges inside the end that hold the filter away from its connection. It turned out that they were just a little to short, putting the end of the filter to close to the connection, and that's all it took to restrict the water flow. I went to the hardware store and found a thin plastic washer that would add some space (it was for a faucet diverter of some kind, thinner than a dime). It added just enough space for good water flow. Another benefit was it helped stop the icemaker line from freezing. A simpler solution might be to make sure to get factory-original filters.
